[petsc-announce] petsc-3.4.4.tar.gz now available
Fri Mar 14 19:09:07 CDT 2014
Dear PETSc users,
The patch release petsc-3.4.4 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
   * MatDense: fix overflow with int32*int32 during malloc()
   * VecView_MPI_DA: fix gsizes bug (bad conversion in parent commit)
   * MATSNESMF: fix so that MatMFFDSetFunction() works correctly with it
   * configure: enable hdf5 even when its not built with a compression library
   * configure: check for ddot_() in chaco and reject it - if found
   * configure: print download package URL before downloading the package
   * MatNullSpaceCreateRigidBody: fix array length for 3D
   * MatMPIAIJGetLocalMat: Correctly check input type of Mat argument
   * Matlab: Fix Matlab viewer for parallel complex vectors
   * Mat: Turned on Fortran binding for MatSetValuesBlockedStencil()
   * Mat: bugfix in MatCreateSeqAIJFromTriple()
   * SNESLINESEARCHBT: Set the norms when exiting early due to negligible step
   * configure: detect if winzip is used to extract petsc.tar.gz and error out
   * configure: check for windows-python and give error message
   * Mat: Check column block size in MatSetBlockSizes
   * Mat: add non-square block support for MatSetValuesBlocked
   * PetscSynchronizedFGets: fix deadlock at EOF
   * Mat: fix bad LogFlops in MatSOR_SeqSBAIJ.
Satish
More information about the petsc-announce mailing list
