[petsc-announce] petsc-3.4.3.tar.gz now available
Tue Oct 15 13:29:40 CDT 2013
Dear PETSc users,
The patch release petsc-3.4.3 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
    * Sys: Fix C/C++ choice for PETSC_RESTRICT and PETSC_STATIC_INLINE.
    * PCGAMG: fix corruption for multiple solves when MatSetNearNullSpace is used
    * Mat: add MATOP_ values for missing functions
    * Intel: Fix error encountered when using Intel compiler and changing gcc on
      PATH between configuring PETSc and building an application.
    * Configure: avoid string argument to __attribute((deprecated))
    * KSPDGMRES: fix conditional variable declarations
    * MatSBAIJ: avoid invalid memory read in MatSOR_SBAIJ
    * BGQ: Work around BG/Q MPI_Bcast bug.
    * PetscOptionsInsertFile: combine Bcasts for alias and values
    * Sys: ex13 avoid non-portable realpath(1) in verification test
    * Sys: fix PetscGetFullPath expansion of ~ and ~user, ensure NULL termination
    * Sys: avoid getpwuid in file path routines
    * MatXAIJSetPreallocation: use array[] notation to help out Fortran
    * Cygwin64: Fix build error with fenv.h
    * MatSchurComplement: Must initialize KSP package
    * SNES: Fix accidental creation of the matrices in SNESNCG used for linear analogue LS.
    * PCGAMG: add man page for PCGAMGType
    * SNES: Fixed SNESComputeJacobianDefaultColor() in the case of multilevel PC
    * Mat: fix Fortran interface for MatGetColumnNorms
    * Bfort: distinguishes between array[] and *pointer to decide whether the
      Fortran interface should have an array or a scalar.
    * DM: Fix for accidentally duplicated refcount decrement in dm->x
    * Doc: PetscLayoutCreate format code block and list
    * Sys: add PetscDataTypeFromString() and test code
    * PCGAMG: Always rebuild coarse Mat the first time
    * PCFactor: add PCFactorGetLevels
    * Dgmres: added option to view deflation vecs after solve.
    * MatPCFactor: include MatFactorShiftType in PCView_Factor output
    * AO: fix erroneous processing of -ao_view and factor into AOViewFromOptions
    * Viewer ASCII: print tabs to petsc_history, not fd
    * PCBJacobi: call KSPSetFromOptions(subksp) when PCSetUp was called first
    * PCGAMG: set bjacobi->same_local_solves=TRUE to clean coarse grid viewing
    * SNESMonitorCancel: enable fortran interface
    * BGQ: fix deadlock on bgq due to inconsistant values returned by getpwuid(getuid())
    * Scalapack: fix build by specifying mpi.h to build
    * MatSeqAIJGetArrayF90: add man pages and fix typo in MatDense version
    * SF docs: add link to summary page and fix title
    * Doc: Fixed DM code in manual
    * VTK: Small fix to error message (.vts to .vtu)
    * Config cmakeboot: add C++ flags any time compiler is available
    * Config OpenMP: check for C++ flag any time the compiler is available
    * Parms: update tarball with fix for namespace conflict with metis
    * Parmetis: update tarball to parmetis-4.0.2-p5 which fixes an install issue with cygwin
    * Viewer: fix Binary Matlab viewer info to use '#' instead of '%'
    * MatSetOption not always logically collective.
    * SNESVI: Fix computation of squared-norm in for the bt linesearch in the VIRS snes case
    * KSPSetDM docs: fix KSPSetDMActive args, add cross-references
    * Vec: fix flop counting to use map->n instead of non-existent map->m
    * Hdf5 installed without zlib should configure without neededing zlib dependency
    * Config: name of configure generated include file confdefs.h did not match name printed in configure.log of conftest.h
    * Vec: put back in flop counts for VecNorm_Seq
    * KSPFGMRES: make KSPMonitor usage match KSPGMRES
    * TS: Tutorial example has no embedded method so needs -ts_adapt_type none
      added MatSetUp calls to TS tutorials 16 and 21
    * DM: Updated DM test ex7.c to use valid command-line options to specify 2D and 3D grids.
    * PCMG: Fixed Fortran binding
    * TS: fix MSVC compiler error: non-POD member of anonymous struct
    * TS tests/ex3: SNESFD and TSComputeIJacobianConstant are incompatible
    * TS: fix shortcut scaling; document TSComputeIJacobianConstant limitations
    * TS: add TSRHSJacobianSetReuse, fixes TSComputeRHSJacobianConstant
    * Zoltan: X is listed as a required dependency of Zoltan but it is only optional
    * Doc: add petsctime.h to SOURCEH (fixes missing docs)
    * ABI: fix ABI compatibility for debug and optimized builds
    * Clang: Fix warning with clang-3.3.
    * Mat Chaco: remove another case of PETSC_DEFAULT out of range of enum
Satish
More information about the petsc-announce mailing list
