incorrect AMD math library link order
Wei-Keng Liao wkliao at northwestern.edu
Wed Mar 20 09:53:30 CDT 2024
Hi, Max
Thanks for the update.
Wei-keng
On Mar 19, 2024, at 7:16 AM, Max R. Dechantsreiter <max at performancejones.com> wrote:
Dear Wei-Keng,
After much trial-and-error, I found that by configuring PnetCDF with
export LIBS='-lamdlibm -lm'
(NOT LIBS='-lamdlibm'), everything was linked with '-lamdlibm -lm'
instead of '-lm -lamdlibm' as it had been before, so the AMD math
library entries should be used in place of their libm counterparts.
I cannot explain why both libamdlibm and libm need to be specified;
but it worked.
Best regards,
Max
President
Performance Jones L.L.C.
Skype: PerformanceJones (UTC+01:00)
+1 414 446-3100 (telephone/voicemail)
https://urldefense.com/v3/__http://www.linkedin.com/in/benchmarking__;!!Dq0X2DkFhyF93HkjWTBQKhk!Q2AZDTjswD1rqsCAzWtdSZ4VJsGlzTZQSlC3-Sg0gBVD9rZmv5PEmUKe1-Q7euvrMz7K7oHx8caeSSKzh2fs4As$
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20240320/8f3835af/attachment.html>
