performance issue
Jim Edwards jedwards at ucar.edu
Fri Aug 11 17:46:49 CDT 2023
Yes that line is called by all processes, but it in turn calls into
pio_getput_int.c line 1159
   ierr = ncmpi_bput_vars_text(file->fh, varid, start, count, fake_stride,
buf, request);
which is called only by MPI_ROOT  (line 1088 of the same file).
On Fri, Aug 11, 2023 at 4:41 PM Wei-Keng Liao <wkliao at northwestern.edu>
wrote:
> I can see line 344 of pioperformance.F90 is called by all processes.
>                    nvarmult= pio_put_var(File, rundate, date//'
> '//time(1:4))
> How do I change it, so it is called by rank 0 only?
> Wei-keng
> On Aug 11, 2023, at 4:25 PM, Jim Edwards <jedwards at ucar.edu> wrote:
> Yes - src/clib/pio_darray_int.c and src/clib/pio_getput_int.c
> I've also attached a couple of darshan dxt profiles.  Both use the same
> lustre file parameters, the first (dxt1.out) is the fast one without the
> scalar write.
> dxt2.out is the slow one.    It seems like adding the scalar is causing
> all of the other writes to get broken up into smaller bits.
> I've also tried moving around where the scalar variable is defined and
> written with respect to the record variables - that doesn't seem to make
> any difference.
> On Fri, Aug 11, 2023 at 3:21 PM Wei-Keng Liao <wkliao at northwestern.edu>
> wrote:
>> Yes, I have.
>> Can you let me know the source codes files that make the PnetCDF API
>> calls?
>> Wei-keng
>> On Aug 11, 2023, at 4:10 PM, Jim Edwards <jedwards at ucar.edu> wrote:
>> Hi Wei-Keng,
>> Sorry about the miscommunication earlier today - I just wanted to confirm
>> that you've been able to reproduce the issue now?
>> On Fri, Aug 11, 2023 at 1:01 PM Jim Edwards <jedwards at ucar.edu> wrote:
>>> I'm sorry - I thought that I had provided that, but I guess not.
>>> repo: git at github.com:jedwards4b/ParallelIO.git
>>> branch: bugtest/lustre
>>> On Fri, Aug 11, 2023 at 12:46 PM Wei-Keng Liao <wkliao at northwestern.edu>
>>> wrote:
>>>> Any particular github branch I should use?
>>>> I got an error during make.
>>>> /global/homes/w/wkliao/PIO/Github/ParallelIO/src/clib/pio_nc4.c:1481:18:
>>>> error: call to undeclared function 'nc_inq_var_filter_ids'; ISO C99 and
>>>> later do not support implicit function declarations
>>>> [-Wimplicit-function-declaration]
>>>>           ierr = nc_inq_var_filter_ids(file->fh, varid, nfiltersp, ids);
>>>> Setting these 2 does not help.
>>>> #undef NC_HAS_ZSTD
>>>> #undef NC_HAS_BZ2
>>>> Wei-keng
>>>> > On Aug 11, 2023, at 12:44 PM, Jim Edwards <jedwards at ucar.edu> wrote:
>>>> > I see I missed answering one question - total 2048 tasks.  (16 nodes)
>>>> > On Fri, Aug 11, 2023 at 11:35 AM Jim Edwards <jedwards at ucar.edu>
>>>> wrote:
>>>> > Here is my run script on perlmutter:
>>>> > #!/usr/bin/env python
>>>> > #SBATCH -A mp9
>>>> > #SBATCH -C cpu
>>>> > #SBATCH --qos=regular
>>>> > #SBATCH --time=15
>>>> > #SBATCH --nodes=16
>>>> > #SBATCH --ntasks-per-node=128
>>>> > import os
>>>> > import glob
>>>> > with open("pioperf.nl
>>>> <https://urldefense.com/v3/__http://pioperf.nl__;!!Dq0X2DkFhyF93HkjWTBQKhk!Wb6cQ1sLURpN2Ny6hale9LwE7W4NZTmSs0o72VGzPYA0zKG52eGy3PPukBWcmzrlC-J0mML7UGxclZF0OT7T_80$>","w")
>>>> as fd:
>>>> >     fd.write("&pioperf\n")
>>>> >     fd.write("  decompfile='ROUNDROBIN'\n")
>>>> > #    for filename in decompfiles:
>>>> > #        fd.write("   '"+filename+"',\n")
>>>> >     fd.write(" varsize=18560\n");
>>>> >     fd.write(" pio_typenames = 'pnetcdf','pnetcdf'\n");
>>>> >     fd.write(" rearrangers = 2\n");
>>>> >     fd.write(" nframes = 1\n");
>>>> >     fd.write(" nvars = 64\n");
>>>> >     fd.write(" niotasks = 16\n");
>>>> >     fd.write(" /\n")
>>>> > os.system("srun -n 2048 ~/parallelio/bld/tests/performance/pioperf ")
>>>> > Module environment:
>>>> > Currently Loaded Modules:
>>>> >   1) craype-x86-milan                        6) cpe/23.03
>>>>     11) craype-accel-nvidia80        16) craype/2.7.20          21)
>>>> cmake/3.24.3
>>>> >   2) libfabric/1.15.2.0
>>>> <https://urldefense.com/v3/__http://1.15.2.0__;!!Dq0X2DkFhyF93HkjWTBQKhk!Wb6cQ1sLURpN2Ny6hale9LwE7W4NZTmSs0o72VGzPYA0zKG52eGy3PPukBWcmzrlC-J0mML7UGxclZF09lbxLQc$>
>>>>                     7) xalt/2.10.2              12) gpu/1.0
>>>>       17) cray-dsmml/0.2.2       22) cray-parallel-netcdf/1.12.3.3
>>>> <https://urldefense.com/v3/__http://1.12.3.3__;!!Dq0X2DkFhyF93HkjWTBQKhk!Wb6cQ1sLURpN2Ny6hale9LwE7W4NZTmSs0o72VGzPYA0zKG52eGy3PPukBWcmzrlC-J0mML7UGxclZF0srcAuMk$>
>>>> >   3) craype-network-ofi                      8)
>>>> Nsight-Compute/2022.1.1  13) evp-patch                    18)
>>>> cray-mpich/8.1.25      23) cray-hdf5/1.12.2.3
>>>> <https://urldefense.com/v3/__http://1.12.2.3__;!!Dq0X2DkFhyF93HkjWTBQKhk!Wb6cQ1sLURpN2Ny6hale9LwE7W4NZTmSs0o72VGzPYA0zKG52eGy3PPukBWcmzrlC-J0mML7UGxclZF0dMhur8g$>
>>>> >   4) xpmem/2.5.2-2.4_3.49__gd0f7936.shasta   9)
>>>> Nsight-Systems/2022.2.1  14) python/3.9-anaconda-2021.11  19) cray-libsci/
>>>> 23.02.1.1
>>>> <https://urldefense.com/v3/__http://23.02.1.1__;!!Dq0X2DkFhyF93HkjWTBQKhk!Wb6cQ1sLURpN2Ny6hale9LwE7W4NZTmSs0o72VGzPYA0zKG52eGy3PPukBWcmzrlC-J0mML7UGxclZF0iCkdumc$>
>>>> 24) cray-netcdf/4.9.0.3
>>>> <https://urldefense.com/v3/__http://4.9.0.3__;!!Dq0X2DkFhyF93HkjWTBQKhk!Wb6cQ1sLURpN2Ny6hale9LwE7W4NZTmSs0o72VGzPYA0zKG52eGy3PPukBWcmzrlC-J0mML7UGxclZF0K5aEvpc$>
>>>> >   5) perftools-base/23.03.0                 10) cudatoolkit/11.7
>>>>    15) intel/2023.1.0               20) PrgEnv-intel/8.3.3
>>>> > cmake command:
>>>> >  CC=mpicc FC=mpifort cmake
>>>> -DPNETCDF_DIR=$CRAY_PARALLEL_NETCDF_DIR/intel/19.0
>>>> -DNETCDF_DIR=$CRAY_NETCDF_PREFIX -DHAVE_PAR_FILTERS=OFF ../
>>>> > There are a couple of issues with the build that can be fixed by
>>>> editing file config.h (created in the bld directory by cmake)
>>>> > Add the following to config.h:
>>>> > #undef NC_HAS_ZSTD
>>>> > #undef NC_HAS_BZ2
>>>> > then:
>>>> > make pioperf
>>>> > once it's built run the submit script from $SCRATCH
>>>> > On Fri, Aug 11, 2023 at 11:13 AM Wei-Keng Liao <
>>>> wkliao at northwestern.edu> wrote:
>>>> > OK. I will test it myself on Perlmutter.
>>>> > Do you have a small test program to reproduce or is it still pioperf?
>>>> > If pioperf, are the build instructions on Perlmutter the same?
>>>> > Please let me know how you run on Perlmutter, i.e. no. process, nodes,
>>>> > Lustre striping, problem size, etc.
>>>> > Does "1 16 64" in your results mean 16 I/O tasks and 64 variables,
>>>> > yes this is correct
>>>> >   and only 16 MPI processes out of total ? processes call PnetCDF
>>>> APIs?
>>>> > yes this is also correct.
>>>> >   Wei-keng
>>>> >> On Aug 11, 2023, at 9:35 AM, Jim Edwards <jedwards at ucar.edu> wrote:
>>>> >> I tried on perlmutter and am seeing the same issue only maybe even
>>>> worse:
>>>> >> RESULT: write    SUBSET         1        16        64
>>>>  1261.0737058071       14.7176171500
>>>>  90.3736534450      205.3695882870
>>>> >> On Fri, Aug 11, 2023 at 8:17 AM Jim Edwards <jedwards at ucar.edu>
>>>> wrote:
>>>> >> Hi Wei-Keng,
>>>> >> I released that the numbers in this table are all showing the slow
>>>> performing file and the fast file
>>>> >> (the one without the scalar variable) are not represented - I will
>>>> rerun and present these numbers again.
>>>> >> Here are corrected numbers for a few cases:
>>>> >> GPFS (/glade/work on derecho):
>>>>  4570.2078677815        4.0610844270
>>>>  4470.3231494386        4.1518251320
>>>> >> Lustre, default PFL's:
>>>>  2808.6570137094        6.6081404420
>>>>  1025.1671656858       18.1043644600
>>>> >> LUSTRE, no PFL's and very wide stripe:
>>>>  4687.6852437580        3.9593102000
>>>>  3001.4741125579        6.1836282120
>>>> >> On Thu, Aug 10, 2023 at 11:34 AM Jim Edwards <jedwards at ucar.edu>
>>>> wrote:
>>>> >> the stripe settings
>>>> >> lfs setstripe -c 96 -S 128M
>>>> >> logs/c96_S128M/
>>>> > Jim Edwards
>>>> > CESM Software Engineer
>>>> > National Center for Atmospheric Research
>>>> > Boulder, CO
>>>> > Jim Edwards
>>>> > Boulder, CO
>>> Jim Edwards
>>> Boulder, CO
>> Jim Edwards
>> Boulder, CO
> Jim Edwards
> Boulder, CO
> <dxt2.out><dxt1.out>
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20230811/41ca853b/attachment.html>
