performance issue
Jim Edwards jedwards at ucar.edu
Mon Aug 7 16:28:55 CDT 2023
Hi Wei-Keng,
The cb_nodes doesn't seem to be affected.
Not using independent mode doesn't seem to have helped.  I have the pioperf
program now writing two files.  One with only
decomposed fields and one with one additional field, rundate, which is a
string with the date in it.
The performance is drastically different:
                                                         IO tasks
vars      Mb/s                           Time (s)
 RESULT: write    SUBSET         1       256        64    12067.7548254854
      25.1577347560    (without scalar)
 RESULT: write    SUBSET         1       256        64      286.4615089145
    1059.8190875640      (with scalar)
On Mon, Aug 7, 2023 at 1:47 PM Wei-Keng Liao <wkliao at northwestern.edu>
wrote:
> Is that the reason for why cb_nodes is 1?
> Strange, because cb_nodes is set at the file open time.
> Entering the independent data mode in PnetCDF can be completely avoided
> if using the nonblocking APIs.
> I would suggest your codes to use the nonblocking APIs in the following
> way.
> /* for non-partitioned variables */
> if (rank == 0) {
>     ncmpi_iput_var_int(fh, varid[0], data[0], &req[0]); /* write the whole
> variable */
>     ncmpi_iput_var_int(fh, varid[1], data[1], &req[1]);
> /* for partitioned variables */
> ncmpi_iput_vara_int(fh, varid[j], data[j], starts[j], counts[j], &req[j]);
> /* commit all posted nonblocking requests */
> ncmpi_wait_all(ncid, NC_REQ_ALL, NC_REQ_NULL, NULL);
> Wei-keng
> > On Aug 7, 2023, at 2:12 PM, Jim Edwards <jedwards at ucar.edu> wrote:
> > Hi Wei-Keng,
> > I think that I've found the problem.   In the model I am writing a
> number of scalar variables to the file as well as the decomposed variables.
> > for the scalar variables I use a code structure like:
> > ncmpi_begin_indep_data(fh);
> > ncmpi_put_vars_int(fh, varid, start, count, stride, data);
> > ncmpi_end_indep_data(fh);
> > In my pioperf test code I didn't write any scalars - this morning I
> added one and the write performance for the decomposed variables got very
> very
> > bad.  What can I do about it?
> > Jim
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20230807/4423a4ce/attachment.html>
