performance issue
Jim Edwards jedwards at ucar.edu
Fri Aug 4 13:27:09 CDT 2023
oh and the pnetcdf version is 1.12.3
On Fri, Aug 4, 2023 at 12:25 PM Jim Edwards <jedwards at ucar.edu> wrote:
> On my list of things to do in PIO is rewriting the error handling code -
> but that issue is the same for both cases and
> so I don't think it would play a role in the difference we are seeing.
> The lfs getstripe output of the two files is nearly identical, I show only
> the cesm file here.
>   lcm_layout_gen:    7
>   lcm_mirror_count:  1
>   lcm_entry_count:   4
>     lcme_id:             1
>     lcme_mirror_id:      0
>     lcme_flags:          init
>     lcme_extent.e_start: 0
>     lcme_extent.e_end:   16777216
>       lmm_stripe_count:  1
>       lmm_stripe_size:   1048576
>       lmm_pattern:       raid0
>       lmm_layout_gen:    0
>       lmm_stripe_offset: 27
>       lmm_objects:
>       - 0: { l_ost_idx: 27, l_fid: [0xa80000401:0x3f2ef8:0x0] }
>     lcme_id:             2
>     lcme_mirror_id:      0
>     lcme_flags:          init
>     lcme_extent.e_start: 16777216
>     lcme_extent.e_end:   17179869184
>       lmm_stripe_count:  4
>       lmm_stripe_size:   16777216
>       lmm_pattern:       raid0
>       lmm_layout_gen:    0
>       lmm_stripe_offset: 35
>       lmm_objects:
>       - 0: { l_ost_idx: 35, l_fid: [0xc80000401:0x3f32e5:0x0] }
>       - 1: { l_ost_idx: 39, l_fid: [0xcc0000402:0x3f3162:0x0] }
>       - 2: { l_ost_idx: 43, l_fid: [0xe80000402:0x3f2f3a:0x0] }
>       - 3: { l_ost_idx: 47, l_fid: [0xec0000401:0x3f3017:0x0] }
>     lcme_id:             3
>     lcme_mirror_id:      0
>     lcme_flags:          init
>     lcme_extent.e_start: 17179869184
>     lcme_extent.e_end:   68719476736
>       lmm_stripe_count:  12
>       lmm_pattern:       raid0
>       lmm_layout_gen:    0
>       lmm_stripe_offset: 16
>       lmm_objects:
>       - 0: { l_ost_idx: 16, l_fid: [0x700000402:0x4021eb:0x0] }
>       - 1: { l_ost_idx: 20, l_fid: [0x740000402:0x4020ae:0x0] }
>       - 2: { l_ost_idx: 24, l_fid: [0x900000400:0x401f68:0x0] }
>       - 3: { l_ost_idx: 28, l_fid: [0x940000400:0x401f71:0x0] }
>       - 4: { l_ost_idx: 32, l_fid: [0xb00000402:0x40220c:0x0] }
>       - 5: { l_ost_idx: 36, l_fid: [0xb40000402:0x40210b:0x0] }
>       - 6: { l_ost_idx: 40, l_fid: [0xd00000402:0x402141:0x0] }
>       - 7: { l_ost_idx: 44, l_fid: [0xd40000400:0x401e90:0x0] }
>       - 8: { l_ost_idx: 48, l_fid: [0xf00000401:0x401e08:0x0] }
>       - 9: { l_ost_idx: 52, l_fid: [0xf40000400:0x401e32:0x0] }
>       - 10: { l_ost_idx: 56, l_fid: [0x1100000402:0x4022e0:0x0] }
>       - 11: { l_ost_idx: 60, l_fid: [0x1140000402:0x4020a6:0x0] }
>     lcme_id:             4
>     lcme_mirror_id:      0
>     lcme_flags:          init
>     lcme_extent.e_start: 68719476736
>     lcme_extent.e_end:   EOF
>       lmm_stripe_count:  24
>       lmm_pattern:       raid0
>       lmm_layout_gen:    0
>       lmm_stripe_offset: 51
>       lmm_objects:
>       - 0: { l_ost_idx: 51, l_fid: [0x1080000400:0x402881:0x0] }
>       - 1: { l_ost_idx: 55, l_fid: [0x10c0000400:0x402955:0x0] }
>       - 2: { l_ost_idx: 59, l_fid: [0x1280000400:0x4027d6:0x0] }
>       - 3: { l_ost_idx: 63, l_fid: [0x12c0000401:0x402ab2:0x0] }
>       - 4: { l_ost_idx: 67, l_fid: [0x1480000400:0x402b75:0x0] }
>       - 5: { l_ost_idx: 71, l_fid: [0x14c0000400:0x4028d2:0x0] }
>       - 6: { l_ost_idx: 75, l_fid: [0x1680000401:0x402a3b:0x0] }
>       - 7: { l_ost_idx: 79, l_fid: [0x16c0000402:0x40294d:0x0] }
>       - 8: { l_ost_idx: 83, l_fid: [0x1880000401:0x40299c:0x0] }
>       - 9: { l_ost_idx: 87, l_fid: [0x18c0000402:0x402f5e:0x0] }
>       - 10: { l_ost_idx: 91, l_fid: [0x1a80000400:0x402a16:0x0] }
>       - 11: { l_ost_idx: 95, l_fid: [0x1ac0000400:0x402bd2:0x0] }
>       - 12: { l_ost_idx: 0, l_fid: [0x300000401:0x402a2e:0x0] }
>       - 13: { l_ost_idx: 4, l_fid: [0x340000402:0x4027d2:0x0] }
>       - 14: { l_ost_idx: 8, l_fid: [0x500000402:0x402a26:0x0] }
>       - 15: { l_ost_idx: 12, l_fid: [0x540000400:0x402943:0x0] }
>       - 16: { l_ost_idx: 64, l_fid: [0x1300000402:0x402c10:0x0] }
>       - 17: { l_ost_idx: 68, l_fid: [0x1340000401:0x4029c6:0x0] }
>       - 18: { l_ost_idx: 72, l_fid: [0x1500000402:0x402d11:0x0] }
>       - 19: { l_ost_idx: 76, l_fid: [0x1540000402:0x402be2:0x0] }
>       - 20: { l_ost_idx: 80, l_fid: [0x1700000400:0x402a64:0x0] }
>       - 21: { l_ost_idx: 84, l_fid: [0x1740000401:0x402b11:0x0] }
>       - 22: { l_ost_idx: 88, l_fid: [0x1900000402:0x402cb8:0x0] }
>       - 23: { l_ost_idx: 92, l_fid: [0x1940000400:0x402cd3:0x0] }
> On Fri, Aug 4, 2023 at 12:12 PM Wei-Keng Liao <wkliao at northwestern.edu>
> wrote:
>> I can see the file header size of 20620 bytes. Because all attributes are
>> stored
>> in the header, the cost of writing them should not be an issue. I also
>> see no gap
>> between 2 consecutive variables, which is good, meaning the write
>> requests made
>> by MPI-IO will be contiguous.
>> If the call sequence of PnetCDF APIs is the same between pioperf and
>> cesm, then
>> the performance should be similarly. Can you check the Lustre striping
>> settings
>> of the 2 output files, using command "lfs getstripe"?
>> If you set any MPI-IO hints, they can also play a role in performance.
>> See the example in PnetCDF for how to dump all hints (function
>> print_info().)
>> https://github.com/Parallel-NetCDF/PnetCDF/blob/master/examples/C/get_info.c
>> If all the above checked out right, then using Darshan should reveal more
>> information.
>> BTW, what PnetCDF version is being used?
>> A comment about PIOc_put_att_tc.
>> * calling MPI_Bcast for checking the error code may not be necessary.
>> PnetCDF does such
>>   check and all metadata consistency check at ncmpi_enddef. If the number
>> of variables
>>   and their attributes are high, then calling lots of MPI_Bcast can be
>> expensive.
>> https://github.com/NCAR/ParallelIO/blob/f45ba898bec31e6cd662ac41f43e0cff14f928b2/src/clib/pio_getput_int.c#L213
>> Wei-keng
>> On Aug 4, 2023, at 12:32 PM, Jim Edwards <jedwards at ucar.edu> wrote:
>> Yes, _enddef is called only once.
>> Here
>> <https://urldefense.com/v3/__https://github.com/NCAR/ParallelIO/blob/main/src/clib/pio_getput_int.c*L128__;Iw!!Dq0X2DkFhyF93HkjWTBQKhk!Rb9IHCtwLvKBflvuPIGfD-peS-Hl1-epxN7yjpgkPoFWdSFS3DFGNkKhfb7WqrC_N0TBJDe-1bKKU_hw4F6HzDo$> is
>> the code that writes attributes.  Here
>> <https://urldefense.com/v3/__https://github.com/NCAR/ParallelIO/blob/main/src/clib/pio_darray_int.c*L661__;Iw!!Dq0X2DkFhyF93HkjWTBQKhk!Rb9IHCtwLvKBflvuPIGfD-peS-Hl1-epxN7yjpgkPoFWdSFS3DFGNkKhfb7WqrC_N0TBJDe-1bKKU_hwOC-tyLY$> is
>> where variables are written.
>> ncoffsets -sg pioperf.2-0256-1.nc
>> <https://urldefense.com/v3/__http://pioperf.2-0256-1.nc__;!!Dq0X2DkFhyF93HkjWTBQKhk!Rb9IHCtwLvKBflvuPIGfD-peS-Hl1-epxN7yjpgkPoFWdSFS3DFGNkKhfb7WqrC_N0TBJDe-1bKKU_hwTlZDyu8$>
>> netcdf pioperf.2-0256-1.nc
>> // file format: CDF-5
>> file header:
>> size   = 7804 bytes
>> extent = 8192 bytes
>> dimensions:
>> dim000001 = 10485762
>> dim000002 = 58
>> time = UNLIMITED // (1 currently)
>> record variables:
>> double vard0001(time, dim000002, dim000001):
>>       start file offset =        8192    (0th record)
>>       end   file offset =  4865401760    (0th record)
>>       size in bytes     =  4865393568    (of one record)
>>       gap from prev var =         388
>> double vard0002(time, dim000002, dim000001):
>>       start file offset =  4865401760    (0th record)
>>       end   file offset =  9730795328    (0th record)
>>       gap from prev var =           0
>> snip
>> double vard0064(time, dim000002, dim000001):
>>       start file offset =306519802976    (0th record)
>>       end   file offset =311385196544    (0th record)
>>  ncoffsets -sg run/
>> SMS_D_Ln9.mpasa7p5_mpasa7p5_mg17.QPC6.derecho_intel.cam-outfrq9s.20230726_094231_iz24v6.cam.h0.0001-01-01-03600.nc
>> <https://urldefense.com/v3/__http://SMS_D_Ln9.mpasa7p5_mpasa7p5_mg17.QPC6.derecho_intel.cam-outfrq9s.20230726_094231_iz24v6.cam.h0.0001-01-01-03600.nc__;!!Dq0X2DkFhyF93HkjWTBQKhk!Rb9IHCtwLvKBflvuPIGfD-peS-Hl1-epxN7yjpgkPoFWdSFS3DFGNkKhfb7WqrC_N0TBJDe-1bKKU_hwdkm0FHQ$>
>> netcdf run/
>> file header:
>> size   = 20620 bytes
>> extent = 16777216 bytes
>> dimensions:
>> ncol = 10485762
>> nbnd = 2
>> chars = 8
>> lev = 58
>> ilev = 59
>> fixed-size variables:
>> double lat(ncol):
>>       start file offset =    16777216
>>       end   file offset =   100663312
>>       size in bytes     =    83886096
>>       gap from prev var =    16756596
>> double lon(ncol):
>>       start file offset =   100663312
>>       end   file offset =   184549408
>> snip
>> int    mdt:
>>       start file offset =   352322552
>>       end   file offset =   352322556
>>       size in bytes     =           4
>> record variables:
>> double time(time):
>>       start file offset =   352322556    (0th record)
>>       end   file offset =   352322564    (0th record)
>>       size in bytes     =           8    (of one record)
>> int    date(time):
>>       start file offset =   352322564    (0th record)
>>       end   file offset =   352322568    (0th record)
>>       size in bytes     =           4    (of one record)
>> snip
>> double STEND_CLUBB(time, lev, ncol):
>>       start file offset =306872117448    (0th record)
>>       end   file offset =311737511016    (0th record)
>> On Fri, Aug 4, 2023 at 10:35 AM Wei-Keng Liao <wkliao at northwestern.edu>
>> wrote:
>>> Can you run command "ncoffsets -sg file.nc
>>> <https://urldefense.com/v3/__http://file.nc__;!!Dq0X2DkFhyF93HkjWTBQKhk!Rb9IHCtwLvKBflvuPIGfD-peS-Hl1-epxN7yjpgkPoFWdSFS3DFGNkKhfb7WqrC_N0TBJDe-1bKKU_hwCtAtD9k$>"
>>> that shows the sizes of file header
>>> and all variables? For the cesm case, is _enddef called only once?
>>> Could you also point me to the program files that call PnetCDF APIs,
>>> including
>>> writing attributes and variables?
>>> Wei-keng
>>> On Aug 4, 2023, at 11:05 AM, Jim Edwards <jedwards at ucar.edu> wrote:
>>> I am using the new ncar system, derecho
>>> <https://urldefense.com/v3/__https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwigtcytrsOAAxWXHjQIHVoDD6YQFnoECBcQAQ&url=https*3A*2F*2Farc.ucar.edu*2Fknowledge_base*2F74317833&usg=AOvVaw2aXlWuOfLnua7fFmIgvfoV&opi=89978449__;JSUlJSU!!Dq0X2DkFhyF93HkjWTBQKhk!Xq6u5krREolkIRHG8AL2taDCmg6HsEdgcEoviUVyzqUINi-ipPM1EhtMcJkQfUYghDhutn7DfH5Wjm57wJ9lQhc$>,
>>> which has a lustre parallel file system.
>>> Looking at the difference between the two headers below makes me wonder
>>> if the issue is with variable attributes?
>>> snip
>>> On Fri, Aug 4, 2023 at 9:39 AM Wei-Keng Liao <wkliao at northwestern.edu>
>>> wrote:
>>>> Hi, Jim
>>>> Can your provide the test program and the file header dumped by "ncdump
>>>> -h", if that is available?
>>>> Also, what machine was used in the tests and its the parallel file
>>>> system configuration is?
>>>> These can help diagnose.
>>>> Wei-keng
>>>> On Aug 4, 2023, at 8:49 AM, Jim Edwards <jedwards at ucar.edu> wrote:
>>>> I am using ncmpi_iput_varn and ncmpi_wait_all to write output from my
>>>> model.   I have a test program that does nothing but test the
>>>> performance of the write operation.   Attached is a plot of performance
>>>> in the model and in the standalone application.   I'm looking for
>>>> clues as to why the model performance is scaling so badly with the
>>>> number of variables but the standalone program performance is fine.
>>>> Jim Edwards
>>>> CESM Software Engineer
>>>> National Center for Atmospheric Research
>>>> Boulder, CO
>>>> <Screenshot 2023-07-27 at 11.49.03 AM.png>
>>> Jim Edwards
>>> Boulder, CO
>> Jim Edwards
>> Boulder, CO
> Jim Edwards
> Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20230804/f47e7c08/attachment-0001.html>
