issue with R8-> R4 conversion
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Oct 18 11:56:49 CDT 2018
Hi Jim
Can you provide a short program that can reproduce the error?
Or let me know the double-precision values that cause NaNF.
I will try to debug with the values.
FYI. The official PnetCDF repo has been migrated to github.
https://github.com/Parallel-NetCDF/PnetCDF <https://github.com/Parallel-NetCDF/PnetCDF>
Wei-keng
> On Oct 18, 2018, at 11:49 AM, Jim Edwards <jedwards at ucar.edu> wrote:
> I am using the latest parallel-netcdf (svn revision 3824) and running into a problem on an IBM pwr9 system with ibm xl compilers.
> The issue is that writing a double-precision in memory variable to a single precision file field results in NaNF in the file.   I tried the same
> case using serial netcdf and the file was written correctly.
> Any ideas?
> Jim Edwards
> CESM Software Engineer
> National Center for Atmospheric Research
> Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20181018/2ce86764/attachment.html>
