Looking for good benchmark to test filesystem performance
Jim Edwards jedwards at ucar.edu
Fri Feb 12 17:12:03 CST 2016
Thanks for the feedback - good luck with your performance issue.
On Fri, Feb 12, 2016 at 4:01 PM, Craig Tierney - NOAA Affiliate <
craig.tierney at noaa.gov> wrote:
> Jim,
> My users aren't using the latest WRF.  Also, we have had a bad experience
> trying to build PIO on NOAA systems.  It has been a challenge and it isn't
> a direction these users want to go at this time.
> Craig
> On Fri, Feb 12, 2016 at 3:56 PM, Jim Edwards <jedwards at ucar.edu> wrote:
>> Hi Craig,
>> In more recent version of wrf there is a pio option that should improve
>> pnetcdf io performance.  Also in the pio distribution is a performance tool
>> that can measure io performance based on the data decomposition you are
>> using in wrf.  https://github.com/NCAR/ParallelIO
>> On Fri, Feb 12, 2016 at 3:34 PM, Craig Tierney - NOAA Affiliate <
>>> Hello All,
>>> I have a user complaining about poor IO performance from WRF when using
>>> pnetcdf 1.6.1.  While I am waiting on real data from the user, I want to
>>> test the filesystem and see what it does to determine if it is WRF or
>>> something else.  I found the list of benchmarks on the website, but there
>>> are many to choose from!  Can someone recommend a single benchmark I should
>>> try?
>>> I have tried the BTIO pnetcdf benchmark.  What I see is that the Lustre
>>> ADIO is no faster than the NFS ADIO when using Intel 15.0.3 and Intel
>>> IMPI.  I have set the variables that Intel MPI requires
>>> (I_MPI_EXTRA_FILESYSTEM and I_MPI_EXTRA_FILESYSTEM_LIST) and the benchmark
>>> is reporting that it is using Lustre.  I am getting 60 MB/s whether I use
>>> 1, 4 or 16 cores.   I would expect the results to be faster.  I want to see
>>> if there is a better benchmark and if so how the result compares to BTIO.
>>> Thanks,
>>> Craig
>> Jim Edwards
>> CESM Software Engineer
>> National Center for Atmospheric Research
>> Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20160212/a0e1e3dd/attachment.html>
