trouble testing/running with gnu/5.1.0
Jim Edwards jedwards at ucar.edu
Mon Jul 20 12:36:27 CDT 2015
I am getting an error when trying to build with gnu/5.1.0
​the traceback looks like:
#6  0x00000000014fb478 in ncmpii_in_swapn ()
#7  0x00000000014cd6be in ncmpii_getput_vars ()
#8  0x00000000014d9b64 in ncmpi_put_vara_int_all ()
#9  0x00000000014baf57 in nfmpi_put_vara_int_all_ ()
#10 0x00000000013f61e2 in __pionfput_mod_MOD_put_vara_1d_int ()
If I try to run the tests with this build I get a hang in the sequentiol
tests:
poe  ./nc_test -v -d       .
   2:*** Testing test_ncmpi_strerror            ...   33 good comparisons.
ok
   0:*** Testing test_ncmpi_strerror            ...   33 good comparisons.
ok
   1:*** Testing test_ncmpi_strerror            ...   33 good comparisons.
ok
   3:*** Testing test_ncmpi_strerror            ...   33 good comparisons.
ok
   0:
   1:
   2:
   2: FAILURE at line 149 of test_read.c: remove of ./scratch.nc failed***
Testing test_ncmpi_open                ...
   2: ### 1 FAILURES TESTING test_ncmpi_open! Stop ... ###
   0:*** TESTING C   ./nc_test for format CDF-1
------ failed
   0:
   0: FAILURE at line 149 of test_read.c: remove of ./scratch.nc failed***
   0: ### 1 FAILURES TESTING test_ncmpi_open! Stop ... ###
   0:
   0:./nc_test: expects 0 failures ... Total number of failures: 1
   1:*** TESTING C   ./nc_test for format CDF-1
------ failed
   1:
   1: FAILURE at line 149 of test_read.c: remove of ./scratch.nc failed***
   1: ### 1 FAILURES TESTING test_ncmpi_open! Stop ... ###
   1:
   1:./nc_test: expects 0 failures ... Total number of failures: 1
   2:*** TESTING C   ./nc_test for format CDF-1
------ failed
   2:
   2:
   2:./nc_test: expects 0 failures ... Total number of failures: 1
   3:*** Testing test_ncmpi_open                ...    5 good comparisons.
ok
and the parallel test fail in the build step with:
glade/apps/opt/modulefiles/ys/cmpwrappers/mpif90 -c -g  -O0
-I../../src/lib  -I../../src/libf -I../../src/libf90  mcoll_testf.f90
*mcoll_testf.f90:257:22:*
         t1 = MPI_Wtime ( )
*                      1*
*Error:* Name '*mpi_wtime*' at (1) is an ambiguous reference to '*mpi_wtime*'
from module '*mpi_constants*'
*mcoll_testf.f90:292:22:*
         t2 = MPI_Wtime ( )
*                      1*
*mcoll_testf.f90:313:20:*
       t3 = MPI_Wtime ( )
*                    1*
All with svn revision 2056​
Jim Edwards
CESM Software Engineer
National Center for Atmospheric Research
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150720/1f4b419d/attachment.html>
