values sporadically set to zero in output arrays
Pfeiffer, Andreas A.Pfeiffer at dlr.de
Mon Aug 17 11:07:42 CDT 2015
I am currently investigating an issue with pnetcdf (1.6.1) writing out
arrays with values wrongly set to zero in some part of my overall domain
of a global climate model (see examples in attachment). This is
happening sporadically only for a very small part of my overall dataset
and only for very few points in time of my simulation. It is
reproducible in a sense that it can be observed for every single
simulation. However, the zeros show up for different variables at
different dates for a simulation that is run several times with the
identical setup.
My first guess would be that this is due to some unfortunate settings
for buffering/flushing e.g. in my pnetcdf and/or mpi-io implementation.
But this might well be the wrong starting point for my investigation.
The examples have been simulated on our cluster (gpfs filesystem version
3.4.0-9) based on openmpi 1.6.5 and compiler intel 14.0.4. Tests with
GNU compilers 4.8.1 did show the same effect.
On a totally different system I did not encounter this problem (so far).
Any hints would be highly appreciated.
Andreas
Dr. Andreas Pfeiffer
Institut fuer Physik der Atmosphaere
DLR Oberpfaffenhofen
Muenchner Str. 20
D-82234 Wessling
Germany
Tel.: +49-8153-28-3958
Fax.: +49-8153-28-1841
Email: a.pfeiffer at dlr.de
www.dlr.de/ipa
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150817/8a93e77a/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150817/8a93e77a/attachment-0003.png>
