use of MPI derived types in Flexible API
Jim Edwards jedwards at ucar.edu
Thu Sep 25 08:04:56 CDT 2014
Taken as an aggregate I'm writing a complete record.
On Wed, Sep 24, 2014 at 7:14 PM, Rob Latham <robl at mcs.anl.gov> wrote:
> On 09/24/2014 07:44 PM, Wei-keng Liao wrote:
>> If the data is contiguous in memory, then there is no need to use varm or
>> flexible APIs.
>> There is a new set of APIs named varn (available in PnetCDF version 1.4.0
>> and later), eg.
>>      ncmpi_put_varn_float_all()
>> It allows a single API call to write a contiguous buffer to a set of
>> noncontiguous places in file.
>> Each noncontiguous place is specified by a (start, count) pair. The
>> start-count pairs can be
>> arbitrary in file offsets (i.e. unsorted order in offsets).
>> Please note this API family is blocking. There is no nonblocking
>> counterpart.
>> In term of performance, this call is equivalent to making multiple iput
>> or bput calls.
> What is the aggregate in-file layout like?  If, taken as a whole, the
> processes need to read/write all of the data then you'll probably be fine.
> If the data is sparse, then we'll probably need to look at some MPI-IO
> tuning, like disabling data sieving in two-phase I/O.
> ==rob
>  Wei-keng
>> On Sep 24, 2014, at 6:58 PM, Jim Edwards wrote:
>>  Data is contiguous in memory but data on a given task maps to various
>>> non contiguous points in the file.   I can guarantee that the data in
>>> memory on a given mpi task is in monotonically increasing order with
>>> respect to offsets into the file, but not more than that.
>>> On Wed, Sep 24, 2014 at 3:43 PM, Wei-keng Liao <
>>> wkliao at eecs.northwestern.edu> wrote:
>>> Hi, Jim
>>> Do you mean the local I/O buffer contains a list of non-contiguous data
>>> in memory?
>>> Or do you mean "distributed" as data is partitioned across multiple MPI
>>> processes?
>>> The varm APIs and the "flexible" APIs that take an MPI derived datatype
>>> argument
>>> are for users to describe non-contiguous data in the local I/O buffer.
>>> The imap
>>> and MPI datatype argument has no effect to the data access in files. So,
>>> I need
>>> to know which case you are referring to first.
>>> Thanks for pointing out the error in the user guide. It is fixed.
>>> Wei-keng
>>> On Sep 24, 2014, at 2:30 PM, Jim Edwards wrote:
>>>  I want to write a distributed variable to a file and the way the
>>>> data is distributed is fairly random with respect to the ordering on
>>>> the file.
>>>> It seems like I can do several things from each task in order to write
>>>> the data -
>>>>        • I can specify several blocks of code using start and count and
>>>> make mulitple calls on each task to ncmpi_bput_vara_all
>>>>        • I can define an MPI derived type and make a single call to
>>>> ncmpi_bput_var_all on each task
>>>>        • I (think I) can use ncmpi_bput_varm_all and specify an imap
>>>> (btw: the pnetcdf users guide has this interface wrong)
>>>> Are any of these better from a performance standpoint?
>>>> Thanks,
>>>> Jim Edwards
>>>> CESM Software Engineer
>>>> National Center for Atmospheric Research
>>>> Boulder, CO
>>> Jim Edwards
>>> Boulder, CO
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20140925/5ded448f/attachment-0001.html>
