mpi error from ncmpi_end_indep_data
Jim Edwards jedwards at ucar.edu
Tue Dec 30 10:31:10 CST 2014
Hi Wei-keng,
I have a code block that looks like:
      ncmpi_begin_indep_data(file->fh);
      usage = 0;
      if(ios->io_rank==file->indep_rank){
ierr = ncmpi_bput_vars_uchar(file->fh, varid, start, count, stride, op,
&request);;
pio_push_request(file, request);
ierr = ncmpi_inq_buffer_usage(ncid, &usage);
// printf("%s %d %d\n",__FILE__,__LINE__,usage);
      ncmpi_end_indep_data(file->fh);
It's generating an error message on the ncmpi_end_indep_data call:
MPI_FILE_WRITE_AT(83): File does not exist
Regardless of the error message the write seems to work fine, any idea
what's causing this?
I'm using pnetcdf svn revision 1920 with intel 15 compiler and mpich.
- Jim
Jim Edwards
CESM Software Engineer
National Center for Atmospheric Research
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20141230/00a89d5e/attachment.html>
