Building errors relating to undefined reference of 'nfmpi_*'
Wei-keng Liao wkliao at ece.northwestern.edu
Thu May 30 22:02:18 CDT 2013
Try
./configure --prefix=/home/wangbin/tools/netcdf/pnetcdf/1.3.1 \
	--with-mpi=/apps/intel/impi/4.0.2.003/intel64/ \
	MPIF77=/apps/intel/impi/4.0.2.003/intel64/bin/mpiifort \
	MPIF90=/apps/intel/impi/4.0.2.003/intel64/bin/mpiifort \
        FC=ifort F90=ifort
Wei-keng
On May 30, 2013, at 9:29 PM, Li Dong wrote:
> Dear Wei-keng,
> It's great! Where can I find the solution?
> Li
> Dr. Li Dong (董理)
> LASG, Institute of Atmospheric Physics
> Chinese Academy of Sciences
> P.O. Box 9804
> Beijing 100029, China
> Phone: 8610-8299 5143
> 在 2013-5-31,上午10:25,Wei-keng Liao <wkliao at ece.northwestern.edu> 写道:
>> Hi, Li,
>> Rob has pointed out the problem and suggested you a solution.
>> Please give it a try and let us know if that works.
>> Wei-keng
>> On May 30, 2013, at 8:08 PM, Li Dong wrote:
>>> Dear Wei-keng,
>>> Thank you for helping! Here is the output in the attachment.
>>> Li
>>> <make.output>
>>> Dr. Li Dong (董理)
>>> P.O. Box 9804
>>> 在 2013-5-30,下午10:43,Wei-keng Liao <wkliao at ece.northwestern.edu> 写道:
>>>> Hi, Li
>>>> It looks like the fortran part of PnetCDF failed to build.
>>>> Could you send us the standard output from the screen when you run "make" command?
>>>> You can do the following command and send us the file "make.output".
>>>> make -s clean; make >& make.output
>>>> Wei-keng
>>>> On May 30, 2013, at 2:48 AM, Li Dong wrote:
>>>>> Dear PnetCDF supporters,
>>>>> When I build parallel-netcdf on our server, I invoked 'make tests' after 'make' and encountered the following errors:
>>>>> /apps/intel/impi/4.0.2.003/intel64/bin/mpiifort -o bigrecords bigrecords.o -L../../src/lib  -lpnetcdf
>>>>> bigrecords.o: In function `MAIN__':
>>>>> bigrecords.F:(.text+0xb0): undefined reference to `nfmpi_create_'
>>>>> bigrecords.F:(.text+0xe6): undefined reference to `nfmpi_def_dim_'
>>>>> bigrecords.F:(.text+0x12b): undefined reference to `nfmpi_def_dim_'
>>>>> bigrecords.F:(.text+0x170): undefined reference to `nfmpi_def_dim_'
>>>>> bigrecords.F:(.text+0x1c2): undefined reference to `nfmpi_def_var_'
>>>>> bigrecords.F:(.text+0x214): undefined reference to `nfmpi_def_var_'
>>>>> bigrecords.F:(.text+0x282): undefined reference to `nfmpi_def_var_'
>>>>> bigrecords.F:(.text+0x2d3): undefined reference to `nfmpi_put_att_text_'
>>>>> bigrecords.F:(.text+0x324): undefined reference to `nfmpi_put_att_text_'
>>>>> bigrecords.F:(.text+0x375): undefined reference to `nfmpi_put_att_text_'
>>>>> bigrecords.F:(.text+0x3c6): undefined reference to `nfmpi_put_att_text_'
>>>>> bigrecords.F:(.text+0x417): undefined reference to `nfmpi_put_att_text_'
>>>>> bigrecords.o:bigrecords.F:(.text+0x468): more undefined references to `nfmpi_put_att_text_' follow
>>>>> bigrecords.F:(.text+0x486): undefined reference to `nfmpi_enddef_'
>>>>> bigrecords.F:(.text+0x4d2): undefined reference to `nfmpi_put_vara_real_all_'
>>>>> bigrecords.F:(.text+0x557): undefined reference to `nfmpi_put_vara_double_all_'
>>>>> bigrecords.F:(.text+0x57e): undefined reference to `nfmpi_close_'
>>>>> bigrecords.F:(.text+0x5c2): undefined reference to `nfmpi_open_'
>>>>> bigrecords.F:(.text+0x5f2): undefined reference to `nfmpi_inq_varid_'
>>>>> bigrecords.F:(.text+0x63e): undefined reference to `nfmpi_get_vara_double_all_'
>>>>> bigrecords.F:(.text+0x65c): undefined reference to `nfmpi_close_'
>>>>> bigrecords.o: In function `writerecs_':
>>>>> bigrecords.F:(.text+0x1165): undefined reference to `nfmpi_put_vara_double_all_'
>>>>> ../../src/lib/libpnetcdf.a(strerrorf.o): In function `nfmpi_strerror_':
>>>>> strerrorf.f:(.text+0x15): undefined reference to `nfmpi_xstrerror_'
>>>>> make[2]: *** [bigrecords] Error 1
>>>>> The config.log file is in the attach and the results of 'uname -a' are:
>>>>> Linux ln1 2.6.18-194.17.1.0.1.el5_lustre.1.8.5 #1 SMP Wed Aug 3 18:09:09 CST 2011 x86_64 x86_64 x86_64 GNU/Linux
>>>>> How to solve this problem? Thanks in advance!
>>>>> Best regards,
>>>>> Li
>>>>> <config.log>
>>>>> Dr. Li Dong (董理)
>>>>> P.O. Box 9804
