Error in MPI_File_open
Aroma Mahendru aroma.mahendru.ece10 at iitbhu.ac.in
Wed Jun 26 15:40:51 CDT 2013
Okay I get this error :
MPI_File_open: MPI_ERR_OTHER: known error not in list
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
So, does this mean there is an older version of openmpi ?The version on the
cluster is Open MPI 1.5.4.
On Wed, Jun 26, 2013 at 4:17 PM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Wed, Jun 26, 2013 at 03:53:57PM -0400, Aroma Mahendru wrote:
> > Actually I did compile and execute the basic mpi program given there. It
> > executed without any errors.  But am I supposed to see any file created
> as
> > well ?
> That simple test program doesn't check for errors.  It ensures your
> MPI library knows about MPI-IO routines.  In 2013 it would be shocking
> if it did not.
> It *should* create a zero-length file called "testfile" in the current
> directory.  If it did not, try again with this version with a bit more
> error checking/reporting:
> static void handle_error(int errcode, const char *str)
>         char msg[MPI_MAX_ERROR_STRING];
>         int resultlen;
>         MPI_Error_string(errcode, msg, &resultlen);
>         fprintf(stderr, "%s: %s\n", str, msg);
>         MPI_Abort(MPI_COMM_WORLD, 1);
> #include <stdio.h>
> #include <mpi.h>
> int main(int argc, char **argv) {
>     MPI_File fh;
>     int ret;
>     MPI_Init(&argc, &argv);
>     ret = MPI_File_open(MPI_COMM_WORLD, "testfile", MPI_MODE_CREATE |
> MPI_MODE_RDWR,
>                   MPI_INFO_NULL, &fh);
>     if (ret != MPI_SUCCESS) handle_error(ret, "MPI_File_open");
>     MPI_File_close(&fh);
>     MPI_Finalize();
>     return 0;
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
Aroma Mahendru
Electronics Engineering
Indian Institute of Technology (BHU)
Varanasi
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130626/80e5e220/attachment.html>
