metadata consistency
Rob Latham robl at mcs.anl.gov
Thu Jul 11 13:21:29 CDT 2013
On Thu, Jul 11, 2013 at 12:09:54PM -0500, Wei-keng Liao wrote:
> One minor correction. The last API in the list I intent to say
> is the family of ncmpi_put_att_<type> APIs. The <type> can be one
> of text, uchar, schar, short, int, ...
I'm a little wary of changing our semantics in such a mature piece of
software.  I think you are right that most people are already doing
this, but it makes me a bit nervous.
the put_att_<type> change has me the most nervous.
It's not as nice as your proposal, but could we just say "rank 0 wins
if there is ever inconsistent metadata" ?
==rob
> Wei-keng
> On Jul 11, 2013, at 12:03 PM, Wei-keng Liao wrote:
> > Dear PnetCDF users,
> > I am working on strengthening the PnetCDF's metadata consistency and
> > would like to change/limit the usage of APIs that modified the
> > metadata (file header) of a netCDF file. These APIs are:
> >    ncmpi_rename_dim(),
> >    ncmpi_rename_var(),
> >    ncmpi_copy_att(),
> >    ncmpi_rename_att(), and
> >    ncmpii_put_att().              <------- correction !
> > (The consistency here is referring to the consistency of file header
> > data stored in memory across all MPI processes.)
> > In netCDF, the above APIs are allowed in data mode if the space
> > required to store the new metadata (attributes, names, etc.) is
> > less than the old one. Otherwise, they must be called in the define
> > mode.
> > In PnetCDF, I would like to change that to allow these APIs only
> > in define mode. If your applications require the above APIs to
> > be called in data mode, please do let me know.
> > Here is my reason for the above change. In data mode, if metadata
> > is changed on one process's memory (or even the change is written
> > to the file by that process because NC_SHARE is set), there is no
> > way to propagate the change from this process to other processes,
> > until ncmpi_close() or ncmpi_sync() is called. If allowing these
> > APIs in define mode only, we can rely on ncmpi_endef() to
> > ensure/check the consistency.
> > Please let me know if your applications will have a problem with
> > such change.
> > (My plan is to make NC_SHARE the default mode for PnetCDF as
> > PnetCDF IS developed to handle parallel access to shared files.
> > The above suggested API changes is the first step of my plan.)
> > Wei-keng
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
