Write a 3D array in Fortran using PnetCDF
MBR MBR mbr.joos at gmail.com
Fri Jan 25 12:08:00 CST 2013
Hi Wei-keng,
The problem was indeed the start... xpos, ypos & zpos started at 0, and I
re-used what I did in parallel HDF5, where the "start" index start at 0 as
in C.
Thanks, and sorry for the dumb question!
Best,
MBR
On Fri, Jan 25, 2013 at 5:07 PM, MBR MBR <mbr.joos at gmail.com> wrote:
> Dear all,
> I'm trying to use PnetCDF to store the variables (which are 3D arrays) of
> my algorithm. Good news is that it seems much simpler than PHDF5 (which I
> already implemented); bad news is that I have a MPI error at runtime I
> cannot understand.
> Please find both the error I get and the piece of code I wrote below. It
> seems to me that it should be quite simple, but I cannot figure out what is
> the problem.
> Any help would be greatly appreciated!
> Best,
> MBR
> The error I get is the following:
> [mypc:18412] *** An error occurred in MPI_Type_create_subarray
> [mypc:18412] *** on communicator MPI_COMM_WORLD
> [mypc:18412] *** MPI_ERR_ARG: invalid argument of some other kind
> [mpyc:18412] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
> Here is a simplified version of the subroutine I wrote, which compiles
> without problems:
> subroutine output(data,x,y,z,nout,myrank)
>   use pnetcdf
>   use mpi_var ! contains useful variables (idim, ni, etc. see below)
>   implicit none
>   include 'mpif.h'
>   ! idim,jdim,kdim are the number of elements in each dimension
>   real(dp),dimension(idim,jdim,kdim) :: data
>   real(dp), dimension(idim) :: x
>   real(dp), dimension(jdim) :: y
>    real(dp), dimension(kdim) :: z
>   integer :: nout, myrank
>   character(LEN=*) :: filename
>   ! PnetCDF variables
>   integer(kind=MPI_OFFSET_KIND) :: nxtot, nytot, nztot
>   integer :: nout, ncid, xdimid, ydimid, zdimid
>   integer, dimension(3) :: sdimid
>   integer :: varid
>   integer(kind=MPI_OFFSET_KIND), dimension(3) :: dims, start, count
>   ! Dimensions; ni,nj,nk are the number of MPI threads per direction
>   nxtot = nx*ni
>   nytot = ny*nj
>   nztot = nz*nk
>   dims = (/ nx, ny, nz /)
>   ! Get filename; nout is the number of the current output
>   call get_filename(nout, filename)
>   ! Create filename
>   nout = nfmpi_create(MPI_COMM_WORLD, filename, NF_CLOBBER, MPI_INFO_NULL,
> ncid)
>   ! Define dimensions
>   nout = nfmpi_def_dim(ncid, "x", nxtot, xdimid)
>   nout = nfmpi_def_dim(ncid, "y", nytot, ydimid)
>   nout = nfmpi_def_dim(ncid, "z", nztot, zdimid)
>   sdimid = (/ xdimid, ydimid, zdimid /)
>   ! Create variable
>   nout = nfmpi_def_var(ncid, "var", NF_DOUBLE, 3, sdimid, varid)
>   ! End of definitions
>   nout = nfmpi_enddef(ncid)
>   ! {x,y,z}pos corresponds to the position of the MPI thread in a 3D
> cartesian grid
>   start = (/ xpos, ypos, zpos /)*dims
>   count = dims
>   ! Write data
>   nout = nfmpi_put_vara_double_all(ncid, varid, start, count, data)
>   ! Close file
>   nout = nfmpi_close(ncid)
> end subroutine output
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130125/278cbb4e/attachment.html>
