Is this the proper way to do parallel reads? and if so, is there a bug?
Smith, Brian E. smithbe at ornl.gov
Thu Jan 10 10:18:13 CST 2013
Is reading collectively across the communicator that opened the file enough?
I have 4 MPI tasks. I create 2 "node" communicators via MPI_Comm_split, then 2 "core" communicators via MPI_Comm_split:
I am world rank 0. IO Rank 0. core rank 0. I will be processing file 0151-01.nc (fh 1) and var VAR1.fcount 0 vcount 0, nc_type 5
I am world rank 2. IO Rank 1. core rank 0. I will be processing file 0158-07.nc (fh 1) and var VAR1. fcount 0 vcount 0, nc_type 5
I am world rank 1. IO Rank 0. core rank 1. I will be processing file 0151-01.nc (fh 1) and var VAR2. fcount 0 vcount 0, nc_type 5
I am world rank 3. IO Rank 1. core rank 1. I will be processing file 0158-07.nc (fh 1) and var VAR2. fcount 0 vcount 0, nc_type 5
So in this case, world rank 0 and world rank 1 are reading different variables out of the same file. They are on the same "node" communicator, so the file is ncmpi_open()ed with that communicator.
Here are the comm splits too. Rankspernode is passed in in this case. I can figure it out on Cray and BlueGene systems, but there isn't a portable way to do that (in MPI2.x) , and I'm just testing on my laptop anyway.
   numnodes = world_size / rankspernode;
   mynode = rank % numnodes; /* generic for laptop testing */
   MPI_Comm_split(MPI_COMM_WORLD, mynode, rank, &iocomm);
   MPI_Comm_rank(iocomm, &iorank);
   MPI_Comm_split(MPI_COMM_WORLD, iorank, rank, &corecomm);
   MPI_Comm_size(corecomm, &numcores);
   MPI_Comm_rank(corecomm, &corerank);
then:
	files_pernode = numfiles / numnodes;
	vars_percore = numvars / numcores;
	for(i = mynode * files_pernode; i < (mynode + 1 ) * files_pernode; i++)
		ncmpi_open(iocomm, fname[i], NC_NOWRITE, MPI_INFO_NULL, &infh);
		for(j = corerank * vars_percore; j < (corerank+1)*vars_percore; j++)
		ncmpi_get_var_float_all(info, vars[j], data)
I'm fairly sure from my printfs (see above) that the communicators are split appropriately for the IO I want to do. However, I'll double check by printing out the communicator pointers too.
Does that make more sense?
Thanks.
On Jan 10, 2013, at 10:43 AM, Rob Latham wrote:
> On Thu, Jan 10, 2013 at 06:53:45AM -0500, Smith, Brian E. wrote:
>> Hi all,
>> I am fairly new to (p)netCDF, but have plenty of MPI experience. I am working on improving IO performance of a fairly simple code I have.
>> The basic premise is:
>> 1) create communicators where the members of the communicator are on the same "node".
>> 2) each "node" opens their subset of the total number of files (say 50 files out of 200 if we have 4 "nodes")
>> 3) each "core" on a given node reads their subset of variables from their node's file. (say 25 out of 100 variables if we have 4 "cores" per "node")
>> 4) each "core" does some local work (right now, just a simple sum)
>> 5) each "node" combines the local work (basically combine local sums for a given var on multiple nodes to a global sum to calculate an average)
>> 6) write results.
> Ah! I think I see a problem in step 3. If there are 100 variables, and
> you want to read those variables collectively, you're going to have to
> get everyone participating, even if the 'count' array is zero for the
> do-nothing processors.
> Maybe you are already doing that...
> If you use the pnetcdf non-blocking interface, you have a bit more
> flexibility: the collective requirement is deferred until the
> ncmpi_wait_all() call  (because in our implementation, all I/O is
> deferred until the ncmpi_wait_all() call).
> You can put yourself into independent mode (must call
> ncmpi_begin_indep_data to flush record variable caches and reset file
> views), but performance is pretty poor. we don't spend any time
> optimizing independent I/O.
>> Depending on how I tweak ncmpi_get_var_*_all vs ncmpi_get_var and indep mode vs collective mode, I get different errors (in all 4 cases though). I think this snippet is the "right" way, so it is what I'd like to focus on.
>> Should this work? I am using pnetcdf 1.2. I will probably try upgrading today to see if that changes the behavior, but I don't see much in the change logs that would suggest that is necessary. This is also linked against MPICH2 1.4.1p1.
>> here's the rough snippet:
>>     fcount = 0;
>>     /* each node handles files, so we need rank in IOcomm */
>>     for(i = IORank * files_pernode; i < (IORank + 1 ) * files_pernode; i++)
>>        fdata[fcount] = (float **)Malloc(sizeof(float *) * vars_percore);
>>        SAFE(ncmpi_open(iocomm, fname[i], NC_NOWRITE, MPI_INFO_NULL, &infh));
>>        vcount = 0;
>>        for(j = coreRank * vars_percore; j < (coreRank + 1) * vars_percore; j++)
>>                 fdata[fcount][vcount] = (float *)Malloc(sizeof(float) * lat * lon);
>>                 SAFE(ncmpi_get_var_float_all(infh, var1[j].varid, fdata[fcount][vcount]));
>> 		  finish_doing_some_local_work();
>> 		 vcount++;
>> 	   do_some_collective_work();
>>           fcount++;
>> I get errors deep inside MPI doing this:
>> #0  0x00007fff8c83bd57 in memmove$VARIANT$sse42 ()
>> #1  0x0000000100052389 in MPIUI_Memcpy ()
>> #2  0x0000000100051ffb in MPIDI_CH3U_Buffer_copy ()
>> #3  0x000000010006792f in MPIDI_Isend_self ()
>> #4  0x0000000100063e72 in MPID_Isend ()
>> #5  0x00000001000a34b5 in PMPI_Isend ()
>> #6  0x00000001000ac8c5 in ADIOI_R_Exchange_data ()
>> #7  0x00000001000aba71 in ADIOI_GEN_ReadStridedColl ()
>> #8  0x00000001000c6545 in MPIOI_File_read_all ()
>> #9  0x00000001000a779f in MPI_File_read_all ()
>> #10 0x000000010001d0c9 in ncmpii_getput_vars (ncp=0x7fff5fbff600, varp=0x100282890, start=0x7fff5fbff600, count=0x7fff5fbff600, stride=0x7fff5fbff600, buf=0x7fff5fbff600, bufcount=3888000, datatype=1275069450, rw_flag=1, io_method=1) at getput_vars.c:741
>> #11 0x0000000100018fc9 in ncmpi_get_var_float_all (ncid=2440416, varid=238391296, ip=0x7fff5fbff670) at getput_var.c:500
>> #12 0x0000000100006e50 in do_fn (fn_params=0x7fff5fbff7b0) at average.c:103
>> #13 0x0000000100000c00 in main (argc=12, argv=0x7fff5fbff9b8) at main.c:47
>> with this failing assert:
>> Assertion failed in file ch3u_buffer.c at line 77: FALSE
>> memcpy argument memory ranges overlap, dst_=0x1048bf000 src_=0x1049bd000 len_=15552000
>> I am testing with 4 processes on my laptop (mpirun -n 4 ./a.out --various-parameters). The communicators are setup as I expect, at least as far as being properly disjoint:
>> What am I doing wrong?
>> Thanks.
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
