nfmpi_inq_buffer_usage
Wei-keng Liao wkliao at ece.northwestern.edu
Tue Nov 6 18:30:09 CST 2012
Hi, Jim
That file was in my working directory, but I forgot to run "svn add" to
add that file. Thanks for point that out and the fix.
Wei-keng
On Nov 6, 2012, at 5:48 PM, Jim Edwards wrote:
> oops, original attachment was incorrect, here is a correction.
> On Tue, Nov 6, 2012 at 4:32 PM, Jim Edwards <jedwards at ucar.edu> wrote:
> Hi Wei-keng,
> The fortran interface defines nfmpi_inq_buf_usage but the function isn't in src/libf.
> I've attached what I think that it should look like.   Can you put this into the repository, and
> update the src/libf/Makefile.in?  I also made an addtional change to pnetcdf_api.interface as shown below.
> Thanks,
> Index: pnetcdf_api.interface
> --- pnetcdf_api.interface       (revision 1101)
> +++ pnetcdf_api.interface       (working copy)
> @@ -2519,7 +2519,7 @@
>                              INTEGER,                       INTENT(IN)  :: varid
>                              INTEGER(KIND=MPI_OFFSET_KIND), INTENT(IN)  :: start(*)
>                              INTEGER(KIND=MPI_OFFSET_KIND), INTENT(IN)  :: count(*)
> -                            CHARACTER(len=*),              INTENT(IN)  :: text
> +                            CHARACTER(len=*),              INTENT(IN)  :: text(*)
>                              INTEGER,                       INTENT(OUT) :: req
>      END FUNCTION   nfmpi_bput_vara_text
> Index: Makefile.in
> --- Makefile.in (revision 1101)
> +++ Makefile.in (working copy)
> @@ -354,7 +354,8 @@
>         bput_varm_doublef.c \
>         bput_varm_int8f.c \
>         bufattachf.c \
> -       bufdetachf.c
> +       bufdetachf.c \
> +        inqbufusagef.c
> Jim Edwards
> CESM Software Engineering Group
> National Center for Atmospheric Research
> Boulder, CO
> 303-497-1842
> Jim Edwards
> Boulder, CO
> 303-497-1842
> <inqbufusagef.c>
