nfmpi_inq_buffer_usage
Jim Edwards jedwards at ucar.edu
Tue Nov 6 17:32:37 CST 2012
Hi Wei-keng,
The fortran interface defines nfmpi_inq_buf_usage but the function isn't in
src/libf.
I've attached what I think that it should look like.   Can you put this
into the repository, and
update the src/libf/Makefile.in?  I also made an addtional change to
pnetcdf_api.interface as shown below.
Index: pnetcdf_api.interface
--- pnetcdf_api.interface       (revision 1101)
+++ pnetcdf_api.interface       (working copy)
@@ -2519,7 +2519,7 @@
                             INTEGER,                       INTENT(IN)  ::
varid
                             INTEGER(KIND=MPI_OFFSET_KIND), INTENT(IN)  ::
start(*)
count(*)
-                            CHARACTER(len=*),              INTENT(IN)  ::
text
+                            CHARACTER(len=*),              INTENT(IN)  ::
text(*)
                             INTEGER,                       INTENT(OUT) ::
req
     END FUNCTION   nfmpi_bput_vara_text
Index: Makefile.in
--- Makefile.in (revision 1101)
+++ Makefile.in (working copy)
@@ -354,7 +354,8 @@
        bput_varm_doublef.c \
        bput_varm_int8f.c \
        bufattachf.c \
-       bufdetachf.c
+       bufdetachf.c \
+        inqbufusagef.c
Jim Edwards
CESM Software Engineering Group
National Center for Atmospheric Research
Boulder, CO
303-497-1842
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20121106/6c4a672d/attachment.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20121106/6c4a672d/attachment.c>
