pnetcdf 1.2.0 create file issue
David Knaak knaak at cray.com
Fri May 11 19:50:23 CDT 2012
Jim,
I'm not intimate  with pnetcdf but the stack trace entries look a little
strange to me.  In particular:
#10
  count=0x1527daa0, stride=0x0
#13
  start=0x7fffffff3750, count=0x7fffffff3750
Could it be that the high level routine is being called with a bad
argument?
Just a thought.
David
On Fri, May 11, 2012 at 05:37:24PM -0600, Jim Edwards wrote:
> Hi David,
> I've updated to the 5.2.5 mpich2 on bluewaters and now get a different problem,
> it happens earlier in the code so I think that this worked in the older
> version, here is a partial stack trace from the core file on 16000 tasks.
> I'll try on Monday to reproduce this on a smaller number of tasks.    Can I
> send you more info when I get it?
> #0  memcpy () at ../sysdeps/x86_64/memcpy.S:102
> #1  0x0000000000c25b03 in MPIDI_CH3U_Buffer_copy ()
> #2  0x0000000000bc91ae in MPIDI_Isend_self ()
> #3  0x0000000000bc5ef4 in MPID_Isend ()
> #4  0x0000000000be4b2b in PMPI_Isend ()
> #5  0x0000000000b9439a in ADIOI_CRAY_R_Exchange_data ()
> #6  0x0000000000b9503d in ADIOI_CRAY_Read_and_exch ()
> #7  0x0000000000b957ca in ADIOI_CRAY_ReadStridedColl ()
> #8  0x0000000000b7ea69 in MPIOI_File_read_all ()
> #9  0x0000000000b7eab6 in PMPI_File_read_all ()
> #10 0x0000000000b3d7ce in ncmpii_getput_vars (ncp=0x107192b0, varp=0x109ee340,
> start=0x15269910, count=0x1527daa0, stride=0x0,
>     buf=0x155f5480, bufcount=245561, datatype=-871890885, rw_flag=1, io_method=
> 1) at ./getput_vars.c:741
> #11 0x0000000000b39804 in ncmpi_get_vara_all (ncid=1, varid=59, start=
> 0x15269910, count=0x1527daa0, buf=0x155f5480,
>     bufcount=245561, datatype=-871890885) at ./getput_vara.c:435
> #12 0x0000000000b092c6 in nfmpi_get_vara_all_ (v1=0x33e8dd8, v2=0x33e89a0, v3=
> 0x418d500, v4=0x418c500, v5=0x155f5480,
>     v6=0x1e72e10, v7=0x1e72e04) at ./get_vara_allf.c:57
> #13 0x00000000007c0524 in pionfread_mod::read_nfdarray_double (file=..., iobuf=
> 0x155f5480, vardesc=..., iodesc=...,
>     start=0x7fffffff3750, count=0x7fffffff3750)
> On Fri, May 11, 2012 at 5:25 PM, Jim Edwards <jedwards at ucar.edu> wrote:
>     David,
>     I will give this a try, thanks.
>     On Fri, May 11, 2012 at 5:15 PM, David Knaak <knaak at cray.com> wrote:
>         Rob,
>         I suggested taking the discussion off line to not bother those not
>         interested in the Cray specifics.  But if you think those on the list
>         are either interested, or don't consider it a bother, I can certainly
>         use the full list.
>         All,
>         In the MPT 5.4.0 release, I made some changes to MPI_File_open to
>         improve scalability.  Because of these changes and previous changes
>         I had made (for added functionality, not because of any bugs), the
>         code was getting very messy.  In fact, I introduced a bug or 2 with
>         these changes.  So in 5.4.3, I significantly restructured the code
>         for better maintainability, fixed the bugs (that I knew of) and made
>         more scalability changes.
>         Jim,
>         The NCSA's "ESS" has the 5.4.2 version of Cray's MPI implementation as
>         default.  The "module list" command output that you included shows:
>           3) xt-mpich2/5.4.2
>         The "module avail xt-mpch2" command shows what other versions are
>         available:
>         h2ologin2 25=>module avail xt-mpich2
>         --------------------- /opt/cray/modulefiles ---------------------
>         xt-mpich2/5.4.2(default)     xt-mpich2/5.4.4       xt-mpich2/5.4.5
>         Would you switch to 5.4.5, relink, and try again?
>         h2ologin2 25=>module swap xt-mpich2/5.4.2 xt-mpich2/5.4.5
>         Thanks.
>         David
>         On Fri, May 11, 2012 at 12:54:39PM -0500, Rob Latham wrote:
>         > On Fri, May 11, 2012 at 11:46:25AM -0500, David Knaak wrote:
>         > > Jim,
>         > > Since you are having this problem on a Cray system, please open a
>         Cray
>         > > bug report against MPI and I will look at it.  We can take further
>         > > discussions off line.
>         > Oh, howdy David! forgot you were on the list.  Thanks for keeping an
>         > eye on things.
>         > the pnetcdf list is pretty low-traffic these days, but we have an
>         > awful lot of users in a cray and Lustre environment.   If you'd
>         rather
>         > discuss cray specific stuff elsewhere, I'd understand, but please let
>         > us know what you figure out.
>         > ==rob
>         > > Thanks.
>         > > David
>         > > On Fri, May 11, 2012 at 10:03:28AM -0600, Jim Edwards wrote:
>         > > > On Fri, May 11, 2012 at 9:43 AM, Rob Latham <robl at mcs.anl.gov>
>         wrote:
>         > > >     On Thu, May 10, 2012 at 03:28:57PM -0600, Jim Edwards wrote:
>         > > >     > This occurs on the ncsa machine bluewaters.   I am using
>         pnetcdf1.2.0 and
>         > > >     > pgi 11.10.0
>         > > >     need one more bit of information: the version of MPT you are
>         using.
>         > > > Sorry, what's mpt?  MPI?
>         > > > Currently Loaded Modulefiles:
>         > > >   1) modules/3.2.6.6                       9)
>         > > > user-paths                           17) xpmem/
>         0.1-2.0400.31280.3.1.gem
>         > > >   2) xtpe-network-gemini                  10) pgi/
>         > > > 11.10.0                          18) xe-sysroot/4.0.46
>         > > >   3) xt-mpich2/5.4.2                      11) xt-libsci/
>         > > > 11.0.04                    19) xt-asyncpe/5.07
>         > > >   4) xtpe-interlagos                      12) udreg/
>         > > > 2.3.1-1.0400.4264.3.1.gem      20) atp/1.4.1
>         > > >   5) eswrap/1.0.12                        13) ugni/
>         > > > 2.3-1.0400.4374.4.88.gem        21) PrgEnv-pgi/4.0.46
>         > > >   6) torque/2.5.10                        14) pmi/
>         > > > 3.0.0-1.0000.8661.28.2807.gem    22) hdf5-parallel/1.8.7
>         > > >   7) moab/6.1.5                           15) dmapp/
>         > > > 3.2.1-1.0400.4255.2.159.gem    23) netcdf-hdf5parallel/4.1.3
>         > > >   8) scripts                              16) gni-headers/
>         > > > 2.1-1.0400.4351.3.1.gem  24) parallel-netcdf/1.2.0
>         > > >     > The issue is that calling nfmpi_createfile would sometimes
>         result in an
>         > > >     > error:
>         > > >     > MPI_File_open : Other I/O error , error stack:
>         > > >     > (unknown)(): Other I/O error
>         > > >     > 126: MPI_File_open : Other I/O error , error stack:
>         > > >     >   Error on create :           502          -32
>         > > >     > The error appears to be intermittent and I could not get it
>         to occur at
>         > > >     all
>         > > >     > on a small number of tasks (160) but it occurs with high
>         frequency when
>         > > >     > using a larger number of tasks (>=1600).    I traced the
>         problem to the
>         > > >     use
>         > > >     > of nf_clobber in the mode argument, removing the nf_clobber
>         seems to have
>         > > >     > solved the problem and I think that create implies clobber
>         anyway doesn't
>         > > >     > it?
>         > > >     > Can someone who knows what is going on under the covers
>         enlighten me
>         > > >     > with some understanding of this issue?   I suspect that one
>         task is
>         > > >     trying
>         > > >     > to clobber the file that another has just created or
>         something of that
>         > > >     > nature.
>         > > >     Unfortunately, "under the covers" here means "inside the
>         MPI-IO
>         > > >     library", which we don't have access to.
>         > > >     in the create case we call MPI_File_open with "MPI_MODE_RDWR
>         > > >     MPI_MODE_CREATE", and  if noclobber set, we add
>         MPI_MODE_EXCL.
>         > > >     OK, so that's pnetcdf.  What's going on in MPI-IO?  Well,
>         cray's based
>         > > >     their MPI-IO off of our ROMIO, but I'm not sure which
>         version.
>         > > >     Let me cook up a quick MPI-IO-only test case you can run to
>         trigger
>         > > >     this problem and then you can beat cray over the head with
>         it.
>         > > > Sounds good, thanks.
>         > > >     ==rob
>         > > >     Rob Latham
>         > > >     Mathematics and Computer Science Division
>         > > >     Argonne National Lab, IL USA
>         > > > Jim Edwards
>         > > > CESM Software Engineering Group
>         > > > National Center for Atmospheric Research
>         > > > Boulder, CO
>         > > > 303-497-1842
>         > Rob Latham
>     Jim Edwards
>     Boulder, CO
>     303-497-1842
> Jim Edwards
> Boulder, CO
> 303-497-1842
