mpi_test analog
Wei-keng Liao wkliao at ece.northwestern.edu
Mon Feb 20 17:42:03 CST 2012
(I should have replied my previous email to the pnetcdf list.)
We are still working on this new API.
The usage will be something like below.
    buf = malloc(buf_size);
    ncmpi_buffer_attach(ncid, buf, buf_size);
    ncmpi_iput_vara_float(...);
    ncmpi_wait_all(...);
    ncmpi_buffer_detach(ncid);
    free(buf);
Wei-keng
On Feb 20, 2012, at 5:24 PM, Jim Edwards wrote:
> Yes - If I understand you correctly I think that it would.   So I would provide the buffer and pnetcdf would handle the task of freeing the memory when the buffer is no longer required?
> On Mon, Feb 20, 2012 at 3:38 PM, Wei-keng Liao <wkliao at ece.northwestern.edu> wrote:
> We (the pnetcdf developers) have been talking about creating a new
> set of APIs analogs to MPI_Bsend, send with user-provided buffering.
> This requires the user to provide a buffer and its size for pnetcdf
> to copy the requests over and to be flushed later. Hence, this memory
> management in pnetcdf can ease the programming work at the application
> end. Will this make sense to your applications?
> Wei-keng
> On Feb 20, 2012, at 3:27 PM, Rob Latham wrote:
> > On Mon, Feb 20, 2012 at 02:15:03PM -0700, Jim Edwards wrote:
> >> The memory overhead is on the application end, I need to make a copy of the
> >> iobuffer, because it is potentially reused for each call and if I do
> >> non-blocking calls it needs to persist.
> > that memory overhead may be a small price to pay if it results in
> > better record variable I/O.
> > the interleaved records really mess up some common collective i/o
> > assumptions.  If however you write out all your record variables in
> > one shot, the i/o request is no longer "aggressively noncontiguous"
> > and performance should be a lot better.
> > ==rob
> >> On Mon, Feb 20, 2012 at 2:01 PM, Wei-keng Liao
> >> <wkliao at ece.northwestern.edu>wrote:
> >>> We have a few yet-to-be-published results (using FLASH and a climate
> >>> application) that show significant improvement of using these
> >>> nonblocking (or we should refer them as "aggregating") APIs.
> >>> Below is a scenario that these APIs can be useful. Say, one
> >>> application has many small sized variables defined and they all
> >>> will be written to a file at about the same time, like checkpointing.
> >>> The blocking APIs allow writing/reading one variable at a time,
> >>> so the performance can be poor. The nonblocking APIs aggregate
> >>> multiple requests into a larger one and hence can result in better
> >>> performance.
> >>> There is not much overhead for the additional memory management,
> >>> as the APIs do not introduce extra memory copy, nor allocating
> >>> additional buffers. The essence of these APIs are to create a
> >>> new, combined MPI file view for the single collective I/O at
> >>> the end.
> >>> Wei-keng
> >>> On Feb 20, 2012, at 2:23 PM, Jim Edwards wrote:
> >>>> Hi Wei-keng,
> >>>> That's the answer that I thought I would get, and no I guess there is no
> >>> point in having one.   Is there a demonstrable performance benefit of this
> >>> non-blocking interface that would make it worth taking on the additional
> >>> memory management that it will require?
> >>>> Jim
> >>>> On Mon, Feb 20, 2012 at 1:18 PM, Wei-keng Liao <
> >>>> Hi, Jim,
> >>>> The "non-blocking" APIs in pnetcdf are not truly asynchronous.
> >>>> They actually defer the I/O requests till ncmpi_wait_all.
> >>>> So, if there is a corresponding test call and it is called
> >>>> in between the post of nonblocking and wait, it will simply
> >>>> return false, indicating not yet complete.
> >>>> Given that, would you still like to see a test API available
> >>>> in pnetcdf? (That will not be too hard to add one.)
> >>>> Wei-keng
> >>>> On Feb 20, 2012, at 1:47 PM, Jim Edwards wrote:
> >>>>> I am working on an async interface using pnetcdf and wondering why
> >>> there is no analog to mpi_test in the API?
> >>>>> Jim Edwards
> >>>>> CESM Software Engineering Group
> >>>>> National Center for Atmospheric Research
> >>>>> Boulder, CO
> >>>>> 303-497-1842
> >>>> Jim Edwards
> > Rob Latham
> > Mathematics and Computer Science Division
> > Argonne National Lab, IL USA
> Jim Edwards
