mpi_test analog
Wei-keng Liao wkliao at ece.northwestern.edu
Mon Feb 20 15:01:20 CST 2012
We have a few yet-to-be-published results (using FLASH and a climate
application) that show significant improvement of using these
nonblocking (or we should refer them as "aggregating") APIs.
Below is a scenario that these APIs can be useful. Say, one
application has many small sized variables defined and they all
will be written to a file at about the same time, like checkpointing.
The blocking APIs allow writing/reading one variable at a time,
so the performance can be poor. The nonblocking APIs aggregate
multiple requests into a larger one and hence can result in better
performance.
There is not much overhead for the additional memory management,
as the APIs do not introduce extra memory copy, nor allocating
additional buffers. The essence of these APIs are to create a
new, combined MPI file view for the single collective I/O at
the end.
Wei-keng
On Feb 20, 2012, at 2:23 PM, Jim Edwards wrote:
> Hi Wei-keng,
> That's the answer that I thought I would get, and no I guess there is no point in having one.   Is there a demonstrable performance benefit of this non-blocking interface that would make it worth taking on the additional memory management that it will require?
> Jim
> On Mon, Feb 20, 2012 at 1:18 PM, Wei-keng Liao <wkliao at ece.northwestern.edu> wrote:
> Hi, Jim,
> The "non-blocking" APIs in pnetcdf are not truly asynchronous.
> They actually defer the I/O requests till ncmpi_wait_all.
> So, if there is a corresponding test call and it is called
> in between the post of nonblocking and wait, it will simply
> return false, indicating not yet complete.
> Given that, would you still like to see a test API available
> in pnetcdf? (That will not be too hard to add one.)
> Wei-keng
> On Feb 20, 2012, at 1:47 PM, Jim Edwards wrote:
> > I am working on an async interface using pnetcdf and wondering why there is no analog to mpi_test in the API?
> > Jim Edwards
> > CESM Software Engineering Group
> > National Center for Atmospheric Research
> > Boulder, CO
> > 303-497-1842
> Jim Edwards
