mpi_test analog
Wei-keng Liao wkliao at ece.northwestern.edu
Mon Feb 20 14:18:13 CST 2012
Hi, Jim,
The "non-blocking" APIs in pnetcdf are not truly asynchronous.
They actually defer the I/O requests till ncmpi_wait_all.
So, if there is a corresponding test call and it is called
in between the post of nonblocking and wait, it will simply
return false, indicating not yet complete.
Given that, would you still like to see a test API available
in pnetcdf? (That will not be too hard to add one.)
Wei-keng
On Feb 20, 2012, at 1:47 PM, Jim Edwards wrote:
> I am working on an async interface using pnetcdf and wondering why there is no analog to mpi_test in the API?
> Jim Edwards
> CESM Software Engineering Group
> National Center for Atmospheric Research
> Boulder, CO
> 303-497-1842
