test release: parallel-netcdf 1.3.0pre1
Wei-keng Liao wkliao at ece.northwestern.edu
Mon Apr 23 13:43:12 CDT 2012
Hi, Jim,
I just built the prerelease 1.3.0pre1 on Intrepid, the BGP at Argonne, but
could not reproduce the error you reported. The Makefile in
src/lib for building ncvalid has the following lines related to ncvalid.
LIBRARY         = libpnetcdf.a
PROGRAM         = ncvalid
$(PROGRAM):     $(PROG_OBJS) $(LIBRARY)
        $(LINK.c) $(PROG_OBJS) $(LIBRARY)
So, it should put the library file at the end of link command.
Could you tell us the configure command line you used and also
send us the src/lib/Makefile?
Here is my configure command line:
./configure --host powerpc-bgp-linux --build powerpc64-suse-linux --with-mpi=/bgsys/drivers/ppcfloor/comm CFLAGS="-Wall -g -O0"
Wei-keng
On Apr 21, 2012, at 8:09 AM, Jim Edwards wrote:
> Hi Rob,
> In building the prerelease the program ncvalid trys to link without libraries - this fails on bgl.   I fixed it by adding $(LIBS) to the link line in the src/lib/Makefile.
> Jim
> On Fri, Mar 30, 2012 at 1:55 PM, Rob Latham <robl at mcs.anl.gov> wrote:
> Hello to our pnetcdf community.
> Did you realize our last release was in August.  Of 2010?  In some
> ways that's great: Parallel-NetCDF churns along, hopefully delivering
> good performance, and we've had no show-stopping bugs come up forcing
> us to make a new release.
> However, development does continue, and we're feeling pretty good
> about the new features in SVN trunk lately, so let's have a
> pre-release so we can get these new features out into applications'
> hands.
> Of particular note:
> - A new "buffered put" api, an extension to the non-blocking
>  interface.  See the release notes for more information.
> - Various bug fixes and optimizations
> - You used to need a custom pnetcdf.h header file from Unidata if you
>  wanted to build NetCDF-4 with parallel-netcdf support.  Now you no
>  longer need their header file.
> For more information, including download or SVN links, please see the
> release notes:
> https://trac.mcs.anl.gov/projects/parallel-netcdf/wiki/ReleaseNotes-1.3.0
> ==rob (on behalf of the entire pnetcdf team at ANL and NWU)
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
> Jim Edwards
