parallel-netcdf problem
rene at iup.physik.uni-bremen.de rene at iup.physik.uni-bremen.de
Fri Apr 20 06:24:07 CDT 2012
Hi
according to the INSTALL file in the parallel-netcdf-1.2.0 one can
write to this address in the hope that someone may help with problem.
Compiling pnetcdf fails with
./configure --prefix=/hb/rene/Bin/netCDF/Bin_parallel-netcdf CC=icc
FC=ifort MPICC=mpicc MPIF=mpif90
at an IBM p770 running on SUSE-Linux ppc64, 2.6.32.36....ppc64
returning
make[3]: Leaving directory
`/gpfs/hb/rene/Bin/netCDF/parallel-netcdf-1.2.0/src/lib'
if [ yes = yes ] ; then cd libf && make ; fi
make[3]: Entering directory
`/gpfs/hb/rene/Bin/netCDF/parallel-netcdf-1.2.0/src/libf'
c  strerrorf.f
make[3]: c: Kommando nicht gefunden
make[3]: [strerrorf.o] Fehler 127 (ignoriert)
c  inq_libversf.f
make[3]: [inq_libversf.o] Fehler 127 (ignoriert)
ar cru ../lib/libpnetcdf.a abortf.o begin_indep_dataf.o closef.o
copy_attf.o createf.o def_dimf.o def_varf.o del_attf.o enddeff.o
end_indep_dataf.o
iget_varm_textf.o iget_varm_int2f.o iget_varm_intf.o iget_varm_realf.o
iget_varm_doublef.o wait_allf.o waitf.o cancelf.o strerrorf.o
inq_libversf.o
ar: strerrorf.o: No such file or directory
make[3]: *** [../lib/libpnetcdf.a] Fehler 1
make[2]: *** [all] Fehler 2
make[2]: Leaving directory
`/gpfs/hb/rene/Bin/netCDF/parallel-netcdf-1.2.0/src'
make[1]: *** [subdir_target] Fehler 1
make[1]: Leaving directory `/gpfs/hb/rene/Bin/netCDF/parallel-netcdf-1.2.0'
make: *** [src/lib/all] Fehler 2
Sorry, its in German, but says that Command not found. Looks like an
error in the Makefile.
Would be great if someone can help.
Regards
Rene Hommel
Research Associate
Bremen University, Environmental Lab
----- Forwarded message from Lehnert at Uni-Bremen.de -----
     Date: Thu, 19 Apr 2012 15:41:59 +0200
  Subject: Re: MPI auf nexus
       To: Rene Hommel <rene.hommel at iup.physik.uni-bremen.de>
parallel-netcdf laesst sich anscheinend
so compilieren:
cd parallel-netcdf-1.2.0
configure --prefix=/hb/rene/xxx \
   CC=icc FC=ifort MPICC=mpicc MPIF77=mpif90
make
----- End forwarded message -----
This message was sent using IMP, the Internet Messaging Program.
