Hints on improving performance with WRF and Pnetcdf
Gerald Creager gerry.creager at tamu.edu
Wed Sep 15 14:28:02 CDT 2010
Rob, I've not had time yet. Instead, I've been spending my days
recovering from a power and chiller failure on the 8th... and another
power failure that night that took our UPS and subsequently our HPC
system down hard. I'll try to get back on it next week...
gerry
Rob Latham wrote:
> On Mon, Sep 06, 2010 at 08:47:15AM -0500, Gerry Creager wrote:
>> Wei-keng Liao wrote:
>>> I have built a ROMIO library with the recent optimizations for Lustre
>>> in my home directory and you are welcomed to give it a try. Below is
>>> the usage example of the library:
>>> %  mpif90 myprogram.o -L/share/home/00531/tg457823/ROMIO/lib -lmpio
>>> Please note that this library is built using mvapich2 on Ranger. Run the
>>> command below before compile/link your programs.
>>> %  module load mvapich2
>> Thanks. Useful information. I'll look at your ROMIO library later
>> today (about to go into a meeting for the rest of the morning).
>> Last time I set stripe-count to homething above 16, rsl files were
>> also "taking advantage" of that and shut down the LFS. Have you seen
>> this or do you address this in ROMIO?
> Hi Gerry, Craig:
> Have either of you tried Wei-keng's library?  We went on a bit of a
> tangent about MPI-IO tests, but that was just to demonstrate that his
> library does work, does provide performance benefits, and does not
> flatten the lustre servers :>
> We can talk about hints for improving performance, too, but Lustre
> needs special attention with respect to collective I/O, attention
> which Wei-keng's library (and MPICH2-1.3.1b1 and newer) do pay to
> Lustre.
> Do mind Wei-keng's suggestions to set the striping configuration on
> the output directory.  If Lustre really does fall over for you
> whenever you stripe across 16 or more servers, then your options for
> parallel I/O are going to be fairly limited.
> In addition to runs with Wei-keng's library (probably the easiest way
> to get the optimizations), can you post the output of 'ncdump -h' of
> one of the slowly-produced output files?
> ==rob
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
