Build Pnet-CDF for Windows and link against MSMPI
Kunal Rao kunalgrao at gmail.com
Wed Oct 20 12:13:01 CDT 2010
Hi Wei-keng,
  Thanks for your reply. I added that printf to print the error message, and
I get this error message:
   Error message : Size of off_t too small for requested format
  What should I do to resolve it ?
Thanks & Regards,
Kunal
On Wed, Oct 20, 2010 at 10:58 AM, Wei-keng Liao <wkliao at ece.northwestern.edu
> wrote:
> Hi, Kunal
> You can use ncmpi_strerror to print the error message. For example,
>   printf("Error message : %s\n", ncmpi_strerror(status));
> This error means the open mode NC_64BIT_OFFSET is not allowed on a 32bit
> machine.
> Try remove it and see if it works.
> Wei-keng
> On Oct 20, 2010, at 5:38 AM, Kunal Rao wrote:
> > Hi
> >   I had planned to do this in June but lost track of it in between. I
> came back to doing this few days back.
> >   Now, I have been able to successfully build the parallel netCDF on
> Windows using mingw compiler with cygwin and link against
> >   MSMPI . ("configure", "make" and "make install" steps were completed
> successfully).
> >   I tried linking this library and the header file with my application
> which supports parallel netcdf.
> >   The compilation of the application went fine, but while running the
> application, I am getting problem with ncmpi_create api.
> >   there is a call to this function as follows:
> >   status = ncmpi_create(MPI_COMM_WORLD, local_filename, NC_CLOBBER |
> NC_64BIT_OFFSET, FILE_INFO_TEMPLATE, file_identifier);
> >   This returns value as -25 and gives error. ( If proper, it should have
> returned 0 I guess..)
> >   Can you please let me know what this return value means and what could
> be going wrong ?
> >   Also, how do I verify if the library built is proper ?
> > Thanks & Regards,
> > Kunal
> > On Fri, Jun 4, 2010 at 3:14 PM, Rob Latham <robl at mcs.anl.gov> wrote:
> > On Fri, Jun 04, 2010 at 03:10:53PM -0400, kunal rao wrote:
> > > Hi,
> > > I would like to build Pnet-CDF for Windows and link against MSMPI. Can
> you
> > > please tell me the steps on how to do that?
> > You are in for something of an adventure.  I don't have any windows
> > experience, but maybe someone on the list does.
> > I think if you used cygwin you might get pretty far, but I don't know
> > how cygwin libraries interact with something like MSMPI.
> > I'll be more than happy to add a README.windows to the distribution if
> > you figure it out :>
> > ==rob
> > Rob Latham
> > Mathematics and Computer Science Division
> > Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20101020/0084291c/attachment.htm>
