Build Pnet-CDF for Windows and link against MSMPI
Kunal Rao kunalgrao at gmail.com
Wed Oct 20 05:38:12 CDT 2010
Hi
  I had planned to do this in June but lost track of it in between. I came
back to doing this few days back.
  Now, I have been able to successfully build the parallel netCDF on Windows
using mingw compiler with cygwin and link against
  MSMPI . ("configure", "make" and "make install" steps were completed
successfully).
  I tried linking this library and the header file with my application which
supports parallel netcdf.
  The compilation of the application went fine, but while running the
application, I am getting problem with ncmpi_create api.
  there is a call to this function as follows:
  status = ncmpi_create(MPI_COMM_WORLD, local_filename, NC_CLOBBER |
NC_64BIT_OFFSET, FILE_INFO_TEMPLATE, file_identifier);
  This returns value as -25 and gives error. ( If proper, it should have
returned 0 I guess..)
  Can you please let me know what this return value means and what could be
going wrong ?
  Also, how do I verify if the library built is proper ?
Thanks & Regards,
Kunal
On Fri, Jun 4, 2010 at 3:14 PM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Fri, Jun 04, 2010 at 03:10:53PM -0400, kunal rao wrote:
> > Hi,
> > I would like to build Pnet-CDF for Windows and link against MSMPI. Can
> you
> > please tell me the steps on how to do that?
> You are in for something of an adventure.  I don't have any windows
> experience, but maybe someone on the list does.
> I think if you used cygwin you might get pretty far, but I don't know
> how cygwin libraries interact with something like MSMPI.
> I'll be more than happy to add a README.windows to the distribution if
> you figure it out :>
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20101020/942930aa/attachment.htm>
