MPI_TYPE_MAX limit using MPT
Nils Smeds nils.smeds at se.ibm.com
Fri Oct 8 07:39:58 CDT 2010
Appears to be something in the SGI MPT that has been around for a long
time and looks like a possible leak in the MPI library rather than in
applications built on top of it?
/Nils
http://www.hdfgroup.org/ftp/HDF5/prev-releases/ReleaseFiles/release5-180
* On IRIX6.5, when the C compiler version is greater than 7.4, complicated
  MPI derived datatype code will work. However, the user should increase
  the value of the MPI_TYPE_MAX environment variable to some appropriate
value
  to use collective irregular selection code.  For example, the current
  parallel HDF5 test needs to raise MPI_TYPE_MAX to 200,000 to pass the
test.
http://www.ks.uiuc.edu/Research/namd/2.6/notes.html
  setenv MPI_REQUEST_MAX 10240
  setenv MPI_TYPE_MAX 10240
Then run NAMD with the following command:
  mpirun -np <procs> namd2 <configfile>
http://spec.unipv.it/mpi/results/res2009q1/mpi2007-20090310-00118.csv
"   setenv MPI_TYPE_MAX 32768"
"     Determines the maximum number of data types that can"
"     simultaneously exist for any single MPI process."
"     MPI generates an error message if this limit (or the default,"
"     if not set) is exceeded.  Default:  1024"
______________________________________________
Nils Smeds,  IBM Deep Computing / World Wide Coordinated Tuning Team
IT Specialist, Mobile phone: +46-70-793 2639
Fax. +46-8-793 9523
Mail address: IBM Sweden; Loc. 5-03; 164 92 Stockholm; SWEDEN
To:     Rob Latham <robl at mcs.anl.gov>
Cc:     parallel-netcdf at lists.mcs.anl.gov
Date:   10/06/2010 07:50 PM
Subject:        Re: MPI_TYPE_MAX limit using MPT
Sent by:        parallel-netcdf-bounces at lists.mcs.anl.gov
My test was indeed using the nonblocking interface; I could re-code with
the blocking interface if you think that would shed some light. The same
test run with mvapich2 didn't encounter any problem.  The MPI_TYPE_MAX
issue is mentioned here
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-February/006647.html
so perhaps it's not pnetcdf that is forgetting to free datatypes.
-Max
On Wed, 6 Oct 2010, Rob Latham wrote:
> On Wed, Oct 06, 2010 at 12:29:50PM -0400, Maxwell Kelley wrote:
>> Is this normal?  Setting MPI_TYPE_MAX to 65536 simply allowed more
>> I/O to be performed before the error appears. The limit is reached
>> more quickly using more processors.  Assuming that this is a case of
>> types not being freed after use, should I just set this limit high
>> enough that it will never be exceeded during a 12-hour batch job?
> I wish we knew more about where the extra data types came from.
> I imagine there is some cost to setting MPI_TYPE_MAX to 2 billion.
> Hopefully, you can find a value that lets you complete your work while
> I try to find the places where pnetcdf forgets to free datatypes.
> Are you still using the nonblocking interface?
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
Såvida annat inte anges ovan: / Unless stated otherwise above:
IBM Svenska AB
Organisationsnummer: 556026-6883
Adress: 164 92 Stockholm
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20101008/030daf0e/attachment.htm>
