MPI_TYPE_MAX limit using MPT
Maxwell Kelley kelley at giss.nasa.gov
Wed Oct 6 12:44:42 CDT 2010
My test was indeed using the nonblocking interface; I could re-code with
the blocking interface if you think that would shed some light. The same
test run with mvapich2 didn't encounter any problem.  The MPI_TYPE_MAX
issue is mentioned here
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-February/006647.html
so perhaps it's not pnetcdf that is forgetting to free datatypes.
-Max
On Wed, 6 Oct 2010, Rob Latham wrote:
> On Wed, Oct 06, 2010 at 12:29:50PM -0400, Maxwell Kelley wrote:
>> Is this normal?  Setting MPI_TYPE_MAX to 65536 simply allowed more
>> I/O to be performed before the error appears. The limit is reached
>> more quickly using more processors.  Assuming that this is a case of
>> types not being freed after use, should I just set this limit high
>> enough that it will never be exceeded during a 12-hour batch job?
> I wish we knew more about where the extra data types came from.
> I imagine there is some cost to setting MPI_TYPE_MAX to 2 billion.
> Hopefully, you can find a value that lets you complete your work while
> I try to find the places where pnetcdf forgets to free datatypes.
> Are you still using the nonblocking interface?
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
