pnetcdf behavior?
Shawn Kim shawn.subscribe at gmail.com
Sun Mar 14 03:55:06 CDT 2010
With your help, now I can trace IO related calls, MPI_File_write_all, in
Flash IO using pnetcdf. Flash IO (or pnetcdf) issues 50 MPI_File_write_all()
function calls, and I logged these calls with timestamps in MPI-level, PVFS2
client, and PVFS2 server. So I know which calls go where.
One weird thing is that there are missing calls in PVFS2 server logs. I got
50 IO calls in MPI-level and PVFS2 client log file, but only 38 calls in
PVFS server logs. I believe that my scheme can even trace collective IO. I
also know that Flash IO does not two phase collective buffering  and
noncontiguous access.
(The same things happened when using Flash IO with hdf5. Hdf5 issues 32
MPI_FIle_write_at_all() and some calls disappear.)
I post this question in pnetcdf, not PVFS2 forum because I think this is
caused by Flash IO or pnetcdf-1.1.1. Actually I tested my mpich2 and pvfs2
with a simple MPI program which uses the same MPI_File_write_all and got all
the correct results.
Do I miss something?
Shawn
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100314/1ac6c587/attachment.htm>
