parallel-netcdf-1.1.1 released
Rob Latham robl at mcs.anl.gov
Thu Jan 28 10:00:54 CST 2010
On Thu, Jan 28, 2010 at 12:13:25AM +0000, Don Morton wrote:
> On Wed, Jan 27, 2010 at 11:57 PM, Don Morton <Don.Morton at alaska.edu> wrote:
> > Okie dokie, I don't know what the root cause is (yet), but it appears that
> > the macros.make (generated by ./configure?) had set the F90 macro to blank,
> > so I just went in and changed it to "ftn" and make install now works.
> Just for the heck of it, I tried setting an F90 environment variable before
> running ./configure, but the resulting macros.make still had a blank for the
> F90 macro...  So, "maybe" this is getting to the root of the problem?
You were so close: in Wei-keng's message you can see that he set
MPIF90.
On the Cray, the "regular" and "mpi" fortran compilers are the same
but on other platforms that is not usually the case.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
