parallel-netcdf-1.1.1 released
Rob Latham robl at mcs.anl.gov
Wed Jan 27 17:36:04 CST 2010
On Wed, Jan 27, 2010 at 05:32:45PM -0600, Rob Latham wrote:
> It looks like configure did not find your fortran 90 compiler.   Did
> you configure pnetcdf with the "--with-mpi=/path/to/implementation"
> flag, or did you set environment variables?
If you use the '--with-mpi=...' method, then maybe your f90 compiler
is called something besides 'mpif90'?
If that's the case, then you will need to set the "MPIF90" environment
variable to the actual MPI F90 compiler.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
