Make installation error
Shawn Kim shawn.subscribe at gmail.com
Wed Jan 20 22:18:46 CST 2010
I am currently using mpich2-1.2 + pvfs-2.8.1 and trying to install
pnetcdf-1.1.0.
I modified rules.make in pnetcdf-1.1.0 and Makefile in
pnetcdf-1.1.0/src/libf. But I didn't add new functions because our cluster
doesn't support svn yet.
When "make install", the error occurred:
$ make install
make[1]: Entering directory
`/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0'
Making `install' in directory
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/src
make[2]: Entering directory
`/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/src'
cd lib && make install
make[3]: Entering directory
`/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/src/lib'
/usr/bin/install -c -d -m 755
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/lib
/usr/bin/install -c -m 644 libpnetcdf.a
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/lib/libpnetcdf.a
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/include
/usr/bin/install -c -m 644 ./pnetcdf.h
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/include/pnetcdf.h
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/man/man3
/usr/bin/install -c -m 644 pnetcdf.3
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/man/man3/pnetcdf.3
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/bin
/usr/bin/install -c -m 755 ncvalid
/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/bin/ncvalid
make[3]: Leaving directory
if [ yes = yes ] ; then cd libf && make install ; fi
`/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/src/libf'
make[3]: Warning: File
`/home/mdl/seokim/io_newest/test/parallel-netcdf-1.1.0/install/include' has
modification time 4.4 s in the future
/bin/rm -f pnetcdf.F90
echo "module pnetcdf" > pnetcdf.F90
/bin/cat pnetcdf.inc >> pnetcdf.F90
/home/mdl/seokim/io_newest/mpich2-1.2.1/bin/mpif77 -c -g -I. -I./../lib
-I../lib   -c pnetcdf.F90
Error: Unexpected end of file in '/tmp/ccFpAkMf.f95'
make[3]: *** [pnetcdf.mod] Error 1
make[2]: *** [install] Error 2
make[2]: Leaving directory
make[1]: *** [subdir_target] Error 1
make[1]: Leaving directory
make: *** [src/lib/install] Error 2
Is there anybody who faced with this kind of problem and solved it?
Could you give me any suggestion?
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100120/a6ca584c/attachment.htm>
