Having a compile issue
Joe Buck jbbuck at gmail.com
Tue Dec 8 12:44:07 CST 2009
Wei-keng,
Thanks for the suggested invocation changes. They seem to have helped (I no
longer have to manually alter the macros.make file) but "make tests" is
still failing, albeit in a different way.
The "make" call goes just fine and the tests up to the fandc directory are
fine and then this one throws a lot of warnings and then an error at the
bottom.
I'm attaching the output from the "configure", "make" and "make test"
invocations.
Here's the output from the failure:
make[2]: Entering directory `/tmp/pnetcdf/test/fandc'
mpif77 -o pnctestf -g  -o pnctestf
/git/parallel-netcdf/test/fandc/pnctestf.F -I../../src/libf/ -L../../src/lib
-lpnetcdf -lm
   MAIN pnf_test:
Warning on line 78 of <stdin>: ignoring text after "end".
Warning on line 78 of <stdin>: local variable nf_request never used
Warning on line 1 of <stdin>: nfmpi_get_varm_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_inq_nvars declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_natts declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: mpi_comm_null_delete_fn declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: mpi_type_null_delete_fn declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_rename_dim declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_inq_dimlen declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_rename_att declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_rename_var declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_inq_attlen declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: mpi_null_copy_fn declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var_double_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_set_default_format declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_inq declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_wtick declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_wtime declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_all declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_dimname declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_attname declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_att_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_varname declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vara_double_all declared EXTERNAL
but never used.
Warning on line 1 of <stdin>: nfmpi_inq_libvers declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_varm_double_all declared EXTERNAL
but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vars_double_all declared EXTERNAL
but never used.
Warning on line 1 of <stdin>: nfmpi_inq_atttype declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_vartype declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_vara_double_all declared EXTERNAL
but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_double_all declared EXTERNAL
but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_int1 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_att_int2 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var_int1 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var_int2 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: mpi_dup_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_vars_double_all declared EXTERNAL
but never used.
Warning on line 1 of <stdin>: nfmpi_open declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_wait declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_int1 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_att_int2 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: pmpi_wtick declared EXTERNAL but never used.
Warning on line 1 of <stdin>: pmpi_wtime declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_sync declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_real declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: mpi_null_delete_fn declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var_int1 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var_int2 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var_real declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vara_all declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_varm_all declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int1 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int2 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_all declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_vardimid declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_vara_all declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_double_all declared EXTERNAL
but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_real declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_unlimdim declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var_real declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_varndims declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_att_text declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var_text declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int1 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int2 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_vars_all declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_varm_all declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_varnatts declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var1_real declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_double_all declared EXTERNAL
but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int1 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_att_text declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var_text declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int2 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_redef declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_real declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int1 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int2 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_abort declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int1 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_text declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int1 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int2 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int2 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_file_info declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_real declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_text declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int1 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int2 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int1 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_real declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_real declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int2 declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_real declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_text declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_real declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_text declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_real declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_text declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_text declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_text declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_delete declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_text declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_end_indep_data declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_att_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_att_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_var_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: mpi_win_null_copy_fn declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_del_att declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_dim declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var1_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_waitall declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_att declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_var declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_var declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vara_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var1 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_vara_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: mpi_comm_null_copy_fn declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_double declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_var1 declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: mpi_type_null_copy_fn declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vara declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_begin_indep_data declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_set_fill declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: mpi_win_dup_fn declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_varm declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vars declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_var_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_copy_att declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_vars declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: mpi_win_null_delete_fn declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_var_text_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_strerror declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_issyserr declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: mpi_conversion_fn_null declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_inq_dimid declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: mpi_comm_dup_fn declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_inq_attid declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_inq_varid declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_inq_ndims declared EXTERNAL but never
used.
Warning on line 1 of <stdin>: nfmpi_get_vara_real_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int1_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int2_all declared EXTERNAL but
never used.
Warning on line 1 of <stdin>: mpi_type_dup_fn declared EXTERNAL but never
used.
/git/parallel-netcdf/test/fandc/pnctestf.F: In function ‘MAIN__’:
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: expected ‘=’, ‘,’,
‘;’, ‘asm’ or ‘__attribute__’ before ‘totsiz_3d__’
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: ‘totsiz_3d__’
undeclared (first use in this function)
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: (Each undeclared
identifier is reported only once
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: for each function it
appears in.)
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: expected expression
before ‘{’ token
/git/parallel-netcdf/test/fandc/pnctestf.F:58: error: expected declaration
specifiers or ‘...’ before ‘longint’
<stdin>:49: warning: passing argument 4 of ‘nfmpi_def_dim__’ makes integer
from pointer without a cast
/git/parallel-netcdf/test/fandc/pnctestf.F:58: note: expected ‘ftnlen’ but
argument is of type ‘integer *’
<stdin>:49: error: too many arguments to function ‘nfmpi_def_dim__’
<stdin>:52: warning: passing argument 4 of ‘nfmpi_def_dim__’ makes integer
<stdin>:52: error: too many arguments to function ‘nfmpi_def_dim__’
<stdin>:54: warning: passing argument 4 of ‘nfmpi_def_dim__’ makes integer
<stdin>:54: error: too many arguments to function ‘nfmpi_def_dim__’
/usr/bin/f77: aborting compilation
make[2]: *** [pnctestf] Error 1
make[2]: Leaving directory `/tmp/pnetcdf/test/fandc'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/tmp/pnetcdf/test'
make: *** [tests] Error 2
-Joe Buck
On Tue, Dec 8, 2009 at 10:00 AM,
<parallel-netcdf-request at lists.mcs.anl.gov>wrote:
> Send parallel-netcdf mailing list submissions to
>        parallel-netcdf at lists.mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>        https://lists.mcs.anl.gov/mailman/listinfo/parallel-netcdf
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        parallel-netcdf-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of parallel-netcdf digest..."
> Today's Topics:
>   1. Re: Having a compile issue (Wei-keng Liao)
> Message: 1
> Date: Tue, 8 Dec 2009 10:41:41 -0600
> From: Wei-keng Liao <wkliao at ece.northwestern.edu>
> Subject: Re: Having a compile issue
> To: parallel-netcdf at lists.mcs.anl.gov
> Message-ID:
>        <51160B0D-DF8E-4982-8ACC-2DA0260F0164 at ece.northwestern.edu>
> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
> Hi, Joe,
> Can you try the followings? (I used these to build pnetcdf under tcsh.)
> autoreconf
> setenv CC     gcc
> setenv CXX    g++
> setenv FC     gfortran
> setenv F90    gfortran
> setenv MPICC  mpicc
> setenv MPICXX mpicxx
> setenv MPIF77 mpif77
> setenv MPIF90 mpif90
> setenv CFLAGS "-g"
> setenv FFLAGS "-g"
> configure --prefix=$HOME/PnetCDF/1.1.0 --enable-fortran
> make
> make tests
> Wei-keng
> On Dec 8, 2009, at 12:40 AM, Joe Buck wrote:
> > I have checked revision 721 out via git. I'm running configure with
> > the --with-mpi flag and with a --prefix path specified. I'm seeing a
> > "make tests" failure in the "fandc" test directory.
> > I'm attaching the output of "configure" , "make" and "make test".
> > One note, it seems like the configure script doesn't pick up my
> > environmental setting of $FC as it does not show up in macros.make
> > file. I had to manually add it.
> > Any advice would be appreciated. Thanks in advance,
> > -Joe Buck
> > <configure.txt><make_tests.txt><make.txt>
> End of parallel-netcdf Digest, Vol 13, Issue 6
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091208/184fea8e/attachment-0001.htm>
checking for top-level source-directory... /git/parallel-netcdf
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking for bison... bison -y
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
configure: checking for m4 preprocessor...
checking for m4... m4
checking m4 flags... -B10000
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking user-defined Fortran-77 compiler "/usr/bin/gfortran"... works
checking for Fortran .F compiler...
checking if Fortran-77 compiler handles *.F files... yes
checking how to make dependencies... false
configure: checking for nm utility...
checking for nm... nm
checking nm flags...
checking for C-equivalent to Fortran routine "SUB"... sub_
configure: checking for math library...
checking for tanh in -lc... no
checking for tanh in -lm... yes
configure: checking for ar utility...
checking for ar... ar
checking ar flags... cru
checking for nm... (cached) nm
checking for ranlib... ranlib
checking for C-equivalent to Fortran routine "SUB_A"... sub_a_
checking MPI-IO support in MPI implementation... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdlib.h... (cached) yes
checking for sys/types.h... (cached) yes
checking for strerror... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for struct stat.st_blksize... yes
checking for IEEE floating point format... yes
checking for size_t... yes
checking if MPI_Offset is size 8... yes
checking for MPI_Request_get_status... yes
checking for MPI_Type_dup... yes
checking for MPI_Info_dup... yes
checking if MPI includes MPI_COMBINER_DUP... yes
checking if MPI includes MPI_COMBINER_HVECTOR_INTEGER... yes
checking if MPI includes MPI_COMBINER_HINDEXED_INTEGER... yes
checking if MPI includes MPI_COMBINER_SUBARRAY... yes
checking if MPI includes MPI_COMBINER_DARRAY... yes
checking if MPI includes MPI_COMBINER_RESIZED... yes
checking if MPI includes MPI_COMBINER_STRUCT_INTEGER... yes
checking if MPI includes MPI_COMBINER_INDEXED_BLOCK... yes
checking if MPI includes MPI_COMBINER_F90_REAL... yes
checking if MPI includes MPI_COMBINER_F90_INTEGER... yes
checking if MPI includes MPI_COMBINER_F90_COMPLEX... yes
checking if MPI includes MPI_CHARACTER... yes
checking if MPI includes MPI_REAL... yes
checking if MPI includes MPI_INTEGER... yes
checking if MPI includes MPI_DOUBLE_PRECISION... yes
checking if MPI includes MPI_INTEGER1... yes
checking if MPI includes MPI_INTEGER2... yes
checking if MPI includes MPI_INTEGER4... yes
checking if MPI includes MPI_INTEGER8... yes
checking if MPI includes MPI_INTEGER16... yes
checking if MPI includes MPI_REAL4... yes
checking if MPI includes MPI_REAL8... yes
checking if MPI includes MPI_REAL16... yes
checking if MPI includes MPI_COMPLEX8... yes
checking if MPI includes MPI_COMPLEX16... yes
checking if MPI includes MPI_COMPLEX32... yes
checking if MPI includes MPI_UB... yes
checking if MPI includes MPI_LB... yes
checking for off_t... yes
checking for ssize_t... yes
checking for ptrdiff_t... yes
checking for uchar... no
checking whether char is unsigned... no
checking whether byte ordering is bigendian... no
checking size of short... 2
checking size of int... 4
checking size of long... 8
checking size of float... 4
checking size of double... 8
checking size of size_t... 8
checking sizeof MPI_Offset... (cached) 8
checking for Fortran "byte"... yes
checking for Fortran "integer*2"... yes
checking if Fortran "byte" is C "signed char"... yes
checking if Fortran "byte" is C "short"... no
checking if Fortran "byte" is C "int"... no
checking if Fortran "byte" is C "long"... no
checking if Fortran "integer*2" is C "short"... yes
checking if Fortran "integer*2" is C "int"... no
checking if Fortran "integer*2" is C "long"... no
checking if Fortran "integer" is C "int"... yes
checking if Fortran "real" is C "float"... yes
checking if Fortran "doubleprecision" is C "double"... yes
checking for Fortran-equivalent to netCDF "byte"... byte
checking for Fortran-equivalent to netCDF "short"... integer*2
checking for Fortran "integer*8"... yes
checking for manual-page index command...
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for library containing MPI_File_sync... none required
checking size of off_t... 8
configure: creating ./config.status
config.status: creating macros.make
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating src/lib/Makefile
config.status: creating src/libf/Makefile
config.status: creating test/common/Makefile
config.status: creating test/test_double/Makefile
config.status: creating test/test_double_int/Makefile
config.status: creating test/test_float/Makefile
config.status: creating test/test_int/Makefile
config.status: creating test/test_dtype/Makefile
config.status: creating test/nc_test/Makefile
config.status: creating test/nf_test/Makefile
config.status: creating test/fandc/Makefile
config.status: creating src/utils/Makefile
config.status: creating src/utils/ncdump/Makefile
config.status: creating src/utils/ncgen/Makefile
config.status: creating test/testcases/Makefile
config.status: creating test/C/Makefile
config.status: creating test/mcoll_perf/Makefile
config.status: creating test/test_check_header/Makefile
config.status: creating test/largefile/Makefile
config.status: creating test/mcoll_fortran/Makefile
config.status: creating src/lib/ncconfig.h
config.status: creating src/libf/pnetcdf.inc
config.status: creating src/libf/nfconfig.inc
parallel-netCDF features:
. parallel-netcdf configured WITH support for large files
. parallel-netcdf configured WITH fortran bindings
. parallel-netcdf configured WITH nonblocking routines
. parallel-netcdf configured WITH giant variable support
make[1]: Entering directory `/tmp/pnetcdf'
Making `all' in directory /tmp/pnetcdf/src
make[2]: Entering directory `/tmp/pnetcdf/src'
cd lib && make
make[3]: Entering directory `/tmp/pnetcdf/src/lib'
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/mpinetcdf.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/header.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/mpincio.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/attr.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/dim.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/error.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/nc.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/ncx.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/string.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/var.c
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/ncmpidtype.c
ar cru libpnetcdf.a mpinetcdf.o header.o mpincio.o attr.o dim.o error.o nc.o ncx.o string.o var.o ncmpidtype.o
ranlib libpnetcdf.a
m4 -B10000 -DAPI=C /git/parallel-netcdf/src/lib/../../man/netcdf.m4 >pnetcdf.3  || rm pnetcdf.3
m4: Warning: `m4 -B' may be removed in a future release
/install/mpich2-121/bin/mpicc -c -g -I.    /git/parallel-netcdf/src/lib/validator.c
/install/mpich2-121/bin/mpicc -o ncvalid -g  validator.o header.o mpincio.o attr.o dim.o nc.o ncx.o string.o error.o var.o
make[3]: Leaving directory `/tmp/pnetcdf/src/lib'
if [ yes = yes ] ; then cd libf && make ; fi
make[3]: Entering directory `/tmp/pnetcdf/src/libf'
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/abortf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/begin_indep_dataf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/closef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/copy_attf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/createf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/def_dimf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/def_varf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/del_attf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/enddeff.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/end_indep_dataf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_att_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_att_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_att_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_att_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_att_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_att_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var1_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var1_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var1_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var1_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var1_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varaf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varsf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_attf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_attidf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_attlenf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_attnamef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_atttypef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_dimf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_dimidf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_dimlenf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_dimnamef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inqf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_nattsf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_ndimsf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_nvarsf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_unlimdimf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_vardimidf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_varf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_varidf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_varnamef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_varnattsf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_varndimsf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/inq_vartypef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/openf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_att_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_att_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_att_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_att_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_att_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_att_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var1_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var1_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var1_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var1_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var1_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varaf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varsf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/redeff.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/rename_attf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/rename_dimf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/rename_varf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/syncf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/nfxutil.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/xstrerrorf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/xinq_libversf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var1_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_var_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vara_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_vars_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var1_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_var_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vara_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_vars_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varmf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_varm_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_doublef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varmf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_int1f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_int2f.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_intf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_realf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/put_varm_textf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/set_fillf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/set_default_formatf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/issyserrf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/get_file_infof.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/deletef.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iput_vara_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iput_vara_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iput_vara_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iput_vara_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iput_vara_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iput_vara_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iput_vara_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iget_vara_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iget_vara_int1_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iget_vara_text_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iget_vara_int2_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iget_vara_int_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iget_vara_real_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/iget_vara_double_allf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/waitallf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/waitf.c
/install/mpich2-121/bin/mpicc -c -g -I. -I/git/parallel-netcdf/src/libf/../lib -I../lib   /git/parallel-netcdf/src/libf/mvar.c
mpif77 -c -g /git/parallel-netcdf/src/libf/strerrorf.f
   nfmpi_strerror:
mpif77 -c -g /git/parallel-netcdf/src/libf/inq_libversf.f
   nfmpi_inq_libvers:
ar cru ../lib/libpnetcdf.a abortf.o begin_indep_dataf.o closef.o copy_attf.o createf.o def_dimf.o def_varf.o del_attf.o enddeff.o end_indep_dataf.o get_att_doublef.o get_att_realf.o get_att_intf.o get_att_int1f.o get_att_int2f.o get_att_textf.o get_var1_doublef.o get_var1f.o get_var1_realf.o get_var1_intf.o get_var1_int2f.o get_var1_textf.o get_vara_allf.o get_vara_double_allf.o get_vara_doublef.o get_varaf.o get_vara_real_allf.o get_vara_realf.o get_vara_int_allf.o get_vara_intf.o get_var_allf.o get_vara_int2_allf.o get_vara_int2f.o get_vara_text_allf.o get_vara_textf.o get_var_double_allf.o get_var_doublef.o get_varf.o get_var_real_allf.o get_var_realf.o get_var_int_allf.o get_var_intf.o get_vars_allf.o get_vars_double_allf.o get_vars_doublef.o get_varsf.o get_vars_real_allf.o get_vars_realf.o get_var_int2_allf.o get_var_int2f.o get_vars_int_allf.o get_vars_intf.o get_vars_int2_allf.o get_vars_int2f.o get_vars_text_allf.o get_vars_textf.o get_var_text_allf.o get_var_textf.o inq_attf.o inq_attidf.o inq_attlenf.o inq_attnamef.o inq_atttypef.o inq_dimf.o inq_dimidf.o inq_dimlenf.o inq_dimnamef.o inqf.o inq_nattsf.o inq_ndimsf.o inq_nvarsf.o inq_unlimdimf.o inq_vardimidf.o inq_varf.o inq_varidf.o inq_varnamef.o inq_varnattsf.o inq_varndimsf.o inq_vartypef.o openf.o put_att_doublef.o put_att_realf.o put_att_intf.o put_att_int1f.o put_att_int2f.o put_att_textf.o put_var1_doublef.o put_var1f.o put_var1_realf.o put_var1_intf.o put_var1_int2f.o put_var1_textf.o put_vara_allf.o put_vara_double_allf.o put_vara_doublef.o put_varaf.o put_vara_real_allf.o put_vara_realf.o put_vara_int_allf.o put_vara_intf.o put_vara_int2_allf.o put_vara_int2f.o put_vara_text_allf.o put_vara_textf.o put_var_doublef.o put_varf.o put_var_realf.o put_var_intf.o put_vars_allf.o put_vars_double_allf.o put_vars_doublef.o put_varsf.o put_vars_real_allf.o put_vars_realf.o put_var_int2f.o put_vars_int_allf.o put_vars_intf.o put_vars_int2_allf.o put_vars_int2f.o put_vars_text_allf.o put_vars_textf.o put_var_textf.o redeff.o rename_attf.o rename_dimf.o rename_varf.o syncf.o nfxutil.o xstrerrorf.o xinq_libversf.o get_var1_int1f.o get_var_int1_allf.o get_var_int1f.o get_vara_int1_allf.o get_vara_int1f.o get_vars_int1_allf.o get_vars_int1f.o put_var1_int1f.o put_var_int1f.o put_vara_int1_allf.o put_vara_int1f.o put_vars_int1_allf.o put_vars_int1f.o get_varm_allf.o get_varm_double_allf.o get_varm_doublef.o get_varmf.o get_varm_int1_allf.o get_varm_int1f.o get_varm_int2_allf.o get_varm_int2f.o get_varm_int_allf.o get_varm_intf.o get_varm_real_allf.o get_varm_realf.o get_varm_text_allf.o get_varm_textf.o put_varm_allf.o put_varm_double_allf.o put_varm_doublef.o put_varmf.o put_varm_int1_allf.o put_varm_int1f.o put_varm_int2_allf.o put_varm_int2f.o put_varm_int_allf.o put_varm_intf.o put_varm_real_allf.o put_varm_realf.o put_varm_text_allf.o put_varm_textf.o set_fillf.o set_default_formatf.o issyserrf.o get_file_infof.o deletef.o iput_vara_allf.o iput_vara_int1_allf.o iput_vara_text_allf.o iput_vara_int2_allf.o iput_vara_int_allf.o iput_vara_real_allf.o iput_vara_double_allf.o iget_vara_allf.o iget_vara_int1_allf.o iget_vara_text_allf.o iget_vara_int2_allf.o iget_vara_int_allf.o iget_vara_real_allf.o iget_vara_double_allf.o waitallf.o waitf.o mvar.o strerrorf.o inq_libversf.o
ranlib ../lib/libpnetcdf.a
make[3]: Leaving directory `/tmp/pnetcdf/src/libf'
cd utils && make
make[3]: Entering directory `/tmp/pnetcdf/src/utils'
cd ncgen && make
make[4]: Entering directory `/tmp/pnetcdf/src/utils/ncgen'
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncgen/../../../src/lib -I/git/parallel-netcdf/src/utils/ncgen -I.   /git/parallel-netcdf/src/utils/ncgen/main.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncgen/../../../src/lib -I/git/parallel-netcdf/src/utils/ncgen -I.   /git/parallel-netcdf/src/utils/ncgen/load.c
bison -y -d /git/parallel-netcdf/src/utils/ncgen/ncgen.y; \
	mv y.tab.c ncgentab.c; \
	mv y.tab.h ncgentab.h
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncgen/../../../src/lib -I/git/parallel-netcdf/src/utils/ncgen -I.   ncgentab.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncgen/../../../src/lib -I/git/parallel-netcdf/src/utils/ncgen -I.   /git/parallel-netcdf/src/utils/ncgen/escapes.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncgen/../../../src/lib -I/git/parallel-netcdf/src/utils/ncgen -I.   /git/parallel-netcdf/src/utils/ncgen/getfill.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncgen/../../../src/lib -I/git/parallel-netcdf/src/utils/ncgen -I.   /git/parallel-netcdf/src/utils/ncgen/init.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncgen/../../../src/lib -I/git/parallel-netcdf/src/utils/ncgen -I.   /git/parallel-netcdf/src/utils/ncgen/genlib.c
/install/mpich2-121/bin/mpicc -o ncmpigen -g  main.o load.o ncgentab.o escapes.o getfill.o init.o genlib.o -L../../../src/lib -lpnetcdf
make[4]: Leaving directory `/tmp/pnetcdf/src/utils/ncgen'
cd ncdump && make
make[4]: Entering directory `/tmp/pnetcdf/src/utils/ncdump'
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncdump/../../../src/lib -I/git/parallel-netcdf/src/utils/ncdump   /git/parallel-netcdf/src/utils/ncdump/ncdump.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncdump/../../../src/lib -I/git/parallel-netcdf/src/utils/ncdump   /git/parallel-netcdf/src/utils/ncdump/vardata.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/src/utils/ncdump/../../../src/lib -I/git/parallel-netcdf/src/utils/ncdump   /git/parallel-netcdf/src/utils/ncdump/dumplib.c
/install/mpich2-121/bin/mpicc -o ncmpidump -g  ncdump.o vardata.o dumplib.o -L../../../src/lib -lpnetcdf
make[4]: Leaving directory `/tmp/pnetcdf/src/utils/ncdump'
make[3]: Leaving directory `/tmp/pnetcdf/src/utils'
make[2]: Leaving directory `/tmp/pnetcdf/src'
Returning to directory /tmp/pnetcdf
make[1]: Leaving directory `/tmp/pnetcdf'
make[1]: Entering directory `/tmp/pnetcdf/test'
set -e; for i in common test_double test_double_int test_float test_int test_dtype nc_test fandc nf_test largefile C mcoll_perf mcoll_fortran test_check_header testcases; do ( cd $i && make ; ) ; done
make[2]: Entering directory `/tmp/pnetcdf/test/common'
/install/mpich2-121/bin/mpicc -g   -c -o testutils.o /git/parallel-netcdf/test/common/testutils.c
ar cru libtestutils.a testutils.o
make[2]: Leaving directory `/tmp/pnetcdf/test/common'
make[2]: Entering directory `/tmp/pnetcdf/test/test_double'
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_double/../../src/lib -I/git/parallel-netcdf/test/test_double/../common  -c /git/parallel-netcdf/test/test_double/test_read.c
/install/mpich2-121/bin/mpicc -o test_read test_read.o -L../../src/lib -L../common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_double/../../src/lib -I/git/parallel-netcdf/test/test_double/../common  -c /git/parallel-netcdf/test/test_double/test_read_indep.c
/install/mpich2-121/bin/mpicc -o test_read_indep test_read_indep.o -L../../src/lib -L../common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_double/../../src/lib -I/git/parallel-netcdf/test/test_double/../common  -c /git/parallel-netcdf/test/test_double/test_write.c
/install/mpich2-121/bin/mpicc -o test_write test_write.o -L../../src/lib -L../common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_double/../../src/lib -I/git/parallel-netcdf/test/test_double/../common  -c /git/parallel-netcdf/test/test_double/test_write_indep.c
/install/mpich2-121/bin/mpicc -o test_write_indep test_write_indep.o -L../../src/lib -L../common  -lpnetcdf -ltestutils
make[2]: Leaving directory `/tmp/pnetcdf/test/test_double'
make[2]: Entering directory `/tmp/pnetcdf/test/test_double_int'
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_double_int/../../src/lib -I/git/parallel-netcdf/test/test_double_int/../common  -c /git/parallel-netcdf/test/test_double_int/test_read.c
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_double_int/../../src/lib -I/git/parallel-netcdf/test/test_double_int/../common  -c /git/parallel-netcdf/test/test_double_int/test_read_indep.c
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_double_int/../../src/lib -I/git/parallel-netcdf/test/test_double_int/../common  -c /git/parallel-netcdf/test/test_double_int/test_write.c
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_double_int/../../src/lib -I/git/parallel-netcdf/test/test_double_int/../common  -c /git/parallel-netcdf/test/test_double_int/test_write_indep.c
make[2]: Leaving directory `/tmp/pnetcdf/test/test_double_int'
make[2]: Entering directory `/tmp/pnetcdf/test/test_float'
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_float/../../src/lib -I/git/parallel-netcdf/test/test_float/../common  -c /git/parallel-netcdf/test/test_float/test_read.c
/install/mpich2-121/bin/mpicc -o test_read test_read.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_float/../../src/lib -I/git/parallel-netcdf/test/test_float/../common  -c /git/parallel-netcdf/test/test_float/test_read_indep.c
/install/mpich2-121/bin/mpicc -o test_read_indep test_read_indep.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_float/../../src/lib -I/git/parallel-netcdf/test/test_float/../common  -c /git/parallel-netcdf/test/test_float/test_write.c
/install/mpich2-121/bin/mpicc -o test_write test_write.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_float/../../src/lib -I/git/parallel-netcdf/test/test_float/../common  -c /git/parallel-netcdf/test/test_float/test_write_indep.c
/install/mpich2-121/bin/mpicc -o test_write_indep test_write_indep.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
make[2]: Leaving directory `/tmp/pnetcdf/test/test_float'
make[2]: Entering directory `/tmp/pnetcdf/test/test_int'
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_int/../../src/lib -I/git/parallel-netcdf/test/test_int/../common  -c /git/parallel-netcdf/test/test_int/test_read.c
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_int/../../src/lib -I/git/parallel-netcdf/test/test_int/../common  -c /git/parallel-netcdf/test/test_int/test_read_indep.c
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_int/../../src/lib -I/git/parallel-netcdf/test/test_int/../common  -c /git/parallel-netcdf/test/test_int/test_write.c
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_int/../../src/lib -I/git/parallel-netcdf/test/test_int/../common  -c /git/parallel-netcdf/test/test_int/test_write_indep.c
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_int/../../src/lib -I/git/parallel-netcdf/test/test_int/../common  -c /git/parallel-netcdf/test/test_int/test_write64.c
/install/mpich2-121/bin/mpicc -o test_write64 test_write64.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_int/../../src/lib -I/git/parallel-netcdf/test/test_int/../common  -c /git/parallel-netcdf/test/test_int/test_read64.c
/install/mpich2-121/bin/mpicc -o test_read64 test_read64.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
make[2]: Leaving directory `/tmp/pnetcdf/test/test_int'
make[2]: Entering directory `/tmp/pnetcdf/test/test_dtype'
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_dtype/../../src/lib  -c /git/parallel-netcdf/test/test_dtype/test_subarray.c
/install/mpich2-121/bin/mpicc -o test_subarray test_subarray.o -L../../src/lib  -lpnetcdf
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_dtype/../../src/lib  -c /git/parallel-netcdf/test/test_dtype/test_darray.c
/install/mpich2-121/bin/mpicc -o test_darray test_darray.o -L../../src/lib  -lpnetcdf
/install/mpich2-121/bin/mpicc -g -I/git/parallel-netcdf/test/test_dtype/../../src/lib  -c /git/parallel-netcdf/test/test_dtype/test_nonblocking.c
/install/mpich2-121/bin/mpicc -o test_nonblocking test_nonblocking.o -L../../src/lib  -lpnetcdf
make[2]: Leaving directory `/tmp/pnetcdf/test/test_dtype'
make[2]: Entering directory `/tmp/pnetcdf/test/nc_test'
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/test/nc_test/../../src/lib -I/git/parallel-netcdf/test/nc_test   /git/parallel-netcdf/test/nc_test/nc_test.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/test/nc_test/../../src/lib -I/git/parallel-netcdf/test/nc_test   /git/parallel-netcdf/test/nc_test/error.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/test/nc_test/../../src/lib -I/git/parallel-netcdf/test/nc_test   /git/parallel-netcdf/test/nc_test/test_get.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/test/nc_test/../../src/lib -I/git/parallel-netcdf/test/nc_test   /git/parallel-netcdf/test/nc_test/test_put.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/test/nc_test/../../src/lib -I/git/parallel-netcdf/test/nc_test   /git/parallel-netcdf/test/nc_test/test_read.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/test/nc_test/../../src/lib -I/git/parallel-netcdf/test/nc_test   /git/parallel-netcdf/test/nc_test/test_write.c
/install/mpich2-121/bin/mpicc -c -g -I/git/parallel-netcdf/test/nc_test/../../src/lib -I/git/parallel-netcdf/test/nc_test   /git/parallel-netcdf/test/nc_test/util.c
/install/mpich2-121/bin/mpicc -o nc_test -g  nc_test.o error.o test_get.o test_put.o test_read.o test_write.o util.o -L../../src/lib -lpnetcdf -lm
make[2]: Leaving directory `/tmp/pnetcdf/test/nc_test'
make[2]: Entering directory `/tmp/pnetcdf/test/fandc'
mpif77 -o pnctestf -g  -o pnctestf /git/parallel-netcdf/test/fandc/pnctestf.F -I../../src/libf/ -L../../src/lib -lpnetcdf -lm
   MAIN pnf_test:
Warning on line 78 of <stdin>: ignoring text after "end".
Warning on line 78 of <stdin>: local variable nf_request never used
Warning on line 1 of <stdin>: nfmpi_get_varm_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_nvars declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_natts declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_comm_null_delete_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_type_null_delete_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_rename_dim declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_dimlen declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_rename_att declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_rename_var declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_attlen declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_null_copy_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_set_default_format declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_wtick declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_wtime declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_dimname declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_attname declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_varname declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_libvers declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_atttype declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_vartype declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_dup_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_open declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_wait declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: pmpi_wtick declared EXTERNAL but never used.
Warning on line 1 of <stdin>: pmpi_wtime declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_sync declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_null_delete_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_vardimid declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_unlimdim declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_varndims declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_varnatts declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_redef declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_abort declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_file_info declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_delete declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_end_indep_data declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_win_null_copy_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_del_att declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_dim declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_waitall declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_att declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_var declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_comm_null_copy_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_type_null_copy_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_begin_indep_data declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_set_fill declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_win_dup_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_copy_att declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_win_null_delete_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_strerror declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_issyserr declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_conversion_fn_null declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_dimid declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_comm_dup_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_attid declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_varid declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_ndims declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_type_dup_fn declared EXTERNAL but never used.
/git/parallel-netcdf/test/fandc/pnctestf.F: In function ‘MAIN__’:
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘totsiz_3d__’
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: ‘totsiz_3d__’ undeclared (first use in this function)
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: (Each undeclared identifier is reported only once
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: for each function it appears in.)
/git/parallel-netcdf/test/fandc/pnctestf.F:34: error: expected expression before ‘{’ token
/git/parallel-netcdf/test/fandc/pnctestf.F:58: error: expected declaration specifiers or ‘...’ before ‘longint’
<stdin>:49: warning: passing argument 4 of ‘nfmpi_def_dim__’ makes integer from pointer without a cast
/git/parallel-netcdf/test/fandc/pnctestf.F:58: note: expected ‘ftnlen’ but argument is of type ‘integer *’
<stdin>:49: error: too many arguments to function ‘nfmpi_def_dim__’
<stdin>:52: warning: passing argument 4 of ‘nfmpi_def_dim__’ makes integer from pointer without a cast
<stdin>:52: error: too many arguments to function ‘nfmpi_def_dim__’
<stdin>:54: warning: passing argument 4 of ‘nfmpi_def_dim__’ makes integer from pointer without a cast
<stdin>:54: error: too many arguments to function ‘nfmpi_def_dim__’
/usr/bin/f77: aborting compilation
make[2]: *** [pnctestf] Error 1
make[2]: Leaving directory `/tmp/pnetcdf/test/fandc'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/tmp/pnetcdf/test'
make: *** [tests] Error 2
