bugy 1.1.0
Rich Lee liequan at slac.stanford.edu
Sat Dec 5 16:17:28 CST 2009
After I made the suggested change, the compiler gave a warning:
nc.c: In function 'ncmpii_NC_enddef':
nc.c:916: warning: overflow in implicit constant conversion
Yes, the change fixed the bug. Thanks for the quick fix!
Best regards,
Lie-Quan
On Sat, Dec 5, 2009 at 10:14 AM, Wei-keng Liao
<wkliao at ece.northwestern.edu>wrote:
> Hi, Lie-Quan,
> Thanks for reporting this bug. Here is a quick fix.
> Please replace the following in file parallel-netcdf-1.1.0/src/lib/nc.c
> old nc.c:
> line 916          alignment = 1;
> new nc.c:
> line 916          alignment = NC_ALIGN_CHUNK;
> Please let us know if that solves your problem.
> Wei-keng
> On Dec 5, 2009, at 2:14 AM, Lie-Quan Lee wrote:
>  Oops, I guess that I may not understand how to run test_double.
>> Anyhow, the redef problem is true. Attached is the testing program to show
>> the probelm. Please help. Thanks.
>> Best regards,
>> Lie-Quan
>> On Fri, Dec 4, 2009 at 10:30 PM, Lie-Quan Lee <liequan at gmail.com> wrote:
>> Dear Parallel-netcdf Developers,
>> I really would like to use version 1.1.0 for its CDF-5 format in our
>> simulation. However, there are some issues (unrelated to CDF-5) in the
>> release 1.1.0. For example, the test_write program under test/test_double
>> failed to generated the right data file (as in test/data/test_double.nc).
>> Here is the ncdump of the resuting data file:
>> netcdf t {
>> dimensions:
>>    x = 100 ;
>>    y = 100 ;
>>    z = 100 ;
>>    time = UNLIMITED ; // (100 currently)
>> variables:
>>    double square(x, y) ;
>>        square:description = "2-D integer array" ;
>>    double cube(x, y, z) ;
>>    double time(time) ;
>>    double xytime(time, x, y) ;
>> // global attributes:
>>        :title = "example netCDF dataset" ;
>> data:
>>  square =
>>  0, nan, 2, nan, 4, nan, 6, nan, 8, nan, 10, nan, 12, nan, 14, nan, 16,
>> nan,
>>    18, nan, 20, nan, 22, nan, 24, nan, 26, nan, 28, nan, 30, nan, 32, nan,
>>    34, nan, 36, nan, 38, nan, 40, nan, 42, nan, 44, nan, 46, nan, 48, nan,
>>    50, nan, 52, nan, 54, nan, 56, nan, 58, nan, 60, nan, 62, nan, 64, nan,
>>    66, nan, 68, nan, 70, nan, 72, nan, 74, nan, 76, nan, 78, nan, 80, nan,
>>    82, nan, 84, nan, 86, nan, 88, nan, 90, nan, 92, nan, 94, nan, 96, nan,
>>    98, nan,
>>  nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan,
>> nan,
>> nan,
>>  200, nan, 202, nan, 204, nan, 206, nan, 208, nan, 210, nan, 212, nan,
>> 214,
>> The testing environment is:
>> OS: Linux x64 (RHEL4)
>> Compiler: gcc 4.2.2
>> MPI: mpich2 1.0.7
>> Also, in my application, open an existing netcdf and add a new variable
>> (2-d) messed up the existing data somehow.  The same code works when
>> parallel-netcdf release 1.0.3 or early is used.
>> Best regards,
>> Lie-Quan Lee
>> SLAC National Accelerator Laboratory
>> <test.cpp>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091205/b8f2cc0c/attachment.htm>
