NCMPI
Dahai Guo dhguo at ncsa.uiuc.edu
Tue Aug 4 16:09:04 CDT 2009
for IOR HPC Benchmark,  there is a filesize limitation of 2 GB for PnetCDF as follow. Do you know the reason, or just a bug? How can I test large file IO in IOR with NCMPI (Certainly I can update the code to 1024 )? do I need to set some special environment varibles for it?
Dahai
line 2162 -- 2165 in IOR.c:
    if ((strcmp(test->api, "NCMPI") == 0)
        && ((test->numTasks * test->blockSize * test->segmentCount)
            > (2*(IOR_offset_t)GIBIBYTE)))
        ERR("file size must be < 2GiB");
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20090804/35114250/attachment.htm>
