benchmark program question
Marty Barnaby mlbarna at sandia.gov
Wed Feb 27 12:18:38 CST 2008
Wei-keng Liao wrote:
> Marty,
> Please see below.
> On Tue, 26 Feb 2008, Marty Barnaby wrote:
>> For my 26 GB/s rate, I don't know many of the specifics the FS itself, except
>> that it what is being called /scratch_grande on our big XT3, Redstorm.
>> For reasons, I didn't choose IOR, but, instead, ran a simple, MPI-executable
>> based on something which had been written by Rob Matzke, for our now defunct
>> SAF IO library project.
>> He basically had a user input parameter for the blocksize, and, after the
>> MPI_File_open, went around on a loop nrecs many times, redumping the same
>> buffer with MPI_File_write_at_all, after recomputing for each processor,
>> respectively, the offset based on the buffer size on the total processor
>> count.
>> We were working on having a real user get his enormous restart in less time,
>> when I decided to find the combination that got me the absolute fastest. I
>> don't have an entire historgram of parameters, but I found that a job where
>> the processor count was the same as the maximum LFS stripe-count (160), and my
>> buffer size was 20 MB per processor, I could consistently get to 26 GB/s for
>> files over 100 GB in total, final size.
> This is interesting. It indicates that setting the number of I/O
> aggregators (cb_nodes in ROMIO hint) the same as the Lustre stripe count
> can provide better I/O performance. Is your 20 MB buffer size the ROMIO
> collective buffer size (hint cb_buffer_size)? It is known that if
> cb_buffer_size is small, there may be several stages of two-phase I/Os
> performed in a single collective I/O call. Providing a large value of
> cb_buffer_size (default is 16 MB now in mpich2-1.0.6) can reduce the
> number of two-phase I/O stages.
Years ago I studied the ROMIO collective IO algorithm intensively,
though I haven't reinspected it recently. I am familiar with the
cb_buffer_size hint, though I don't know what the default is, and that
the cb_nodes default is the number or processors in the communicator. In
achieving my byte-rate for the storage, I was assuming that I was
getting no memory exchanging under the MPI_File_write call, and, since
the disjoint offset for each processors chunk of the total vector was
provided explicitly, I am, essentially getting a barriered, coordinated,
independent write from all the processors.
>> I thought this had no practical value at the time, since it means having
>> 3.3 GB across the communicator for one, collective, field or variable
>> store operation. However, now I'm seeing fields this large, and think
>> that this may approach representing the second part of a properly
>> applied 2-phase aggregation. Besides that already available in ROMIO, I
>> am working with the CAM code from UCAR, where they have written their
>> own IO package that applies the primary phase in a specific manner,
>> usually involving 'rearrangement'; turning a large number of small
>> buffers into a small number of larger ones, on a subset of the global
>> communicators processors, then performs the writes via PNetCDF.
> I have some experience on I/O rearrangement. I found that if the ROMIO
> file domain is partitioned aligned with the stripe boundaries, the I/O
> performance can be enhanced significantly. Experiment results can be found
> in my IPDPS07 paper.
>  "An Implementation and Evaluation of Client-Side File Caching for MPI-IO"
> The alignment is tested in ROMIO and enabled by a hint, but this feature
> has not been incorported in the ROMIO release yet.
> Wei-keng
My understanding is that the 'rearranging' of the PIO library for the
CAM code focuses on the structure of their 3-D mesh, and something about
how they want to perceive the information resulting from a calculation.
I don't believe it has any connection or concern for underlying storage
configuration, like aligning on boundaries. In my experience, though
scientific application developers express a concern about I/O
performance, they have no interest in investing project resources or
effort, particularly if the may require compromises, to achieve much
faster rates. Presently, most have to spend anything left after coding
their newest models, on the V and V of their execution and results, no
matter how long it takes to get them.
Marty
>> Marty
>>> Hi,
>>> IOR benchmark includes pnetcdf. http://sourceforge.net/projects/ior-sio
>>> Its pnetcdf was recently modified to use record variables. That should
>>> take care of the file appending I/O mode.
>>> I am interested in your results of 26 GB/s on Lustre using MPI-IO on
>>> shared files. My experience was about 15 GB/s top on Jaguar @ORNL using an
>>> application I/O kernel whose data partitioning patterns are 3D
>>> block-block-block. But the results were obtained when Jaguar was running
>>> catamount. Jaguar is currently under upgrade to new hardware and software.
>>> I would appreciate if you can share your results.
>>> Wei-keng
>>>> I'm new to the parallel NetCDF interface, and I don't have much
>>>> experience with NetCDF either. Because of new interest on our part, we
>>>> would like to have a straightforward, benchmark program to get byte-rate
>>>> metrics for writing to a Posix FS (chiefly, some large Lustre
>>>> deployments). I've had some reasonable experiences in this at the MPI-IO
>>>> level, achieving a sustained, average rate of 26 GB/s; this writing to a
>>>> single, shared file with an LFS stripe-count of 160. If anyone is
>>>> interested, I could provide them with more specifics.
>>>> I can't find the benchmark-type code that I really need, though I've
>>>> been looking at the material under /test like /test_double/test_write.c
>>>> This I've compiled and executed successfully at the appropriate -np 4
>>>> level.
>>>> There are three dynamics I would like to have that I can't see how to
>>>> get.
>>>>   1. Run on any number of processors. I'm sure this is simple, but I want
>>>>   to
>>>>       know where the failure is when I attempt it.
>>>>   2. Set the number of bytes appended to an open file in a single, atomic,
>>>>       collective write operation. In my MPI-IO benchmark program I merely
>>>>       got this number by having a buffer size on each processor, and
>>>> the total
>>>>       was the product of this times the number of processors. At the
>>>>       higher
>>>>       level of PNetCDF I'm not sure which value I'm getting in the def_var
>>>>       and put_var.
>>>>   3. Be able to perform any number of equivalent, collective write
>>>>   operations,
>>>>       appending to the same, open file. Simply a:
>>>>       for ( i = 0; i < NUMRECS; i++ )
>>>>       concept. This is basically what our scientific, simulation
>>>> applications
>>>> do in their 'dump' mode.
>>>> Thanks,
>>>> Marty Barnaby
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20080227/619f0e92/attachment.htm>
