benchmark program question
Rob Ross rross at mcs.anl.gov
Tue Feb 26 12:41:09 CST 2008
Hi Marty, I think that IOR (from LLNL) will let you do this stuff. --
Rob
On Feb 26, 2008, at 10:22 AM, Marty Barnaby wrote:
> I'm new to the parallel NetCDF interface, and I don't have much
> experience with NetCDF either. Because of new interest on our part,
> we would like to have a straightforward, benchmark program to get
> byte-rate metrics for writing to a Posix FS (chiefly, some large
> Lustre deployments). I've had some reasonable experiences in this at
> the MPI-IO level, achieving a sustained, average rate of 26 GB/s;
> this writing to a single, shared file with an LFS stripe-count of
> 160. If anyone is interested, I could provide them with more
> specifics.
> I can't find the benchmark-type code that I really need, though I've
> been looking at the material under /test like /test_double/
> test_write.c
> This I've compiled and executed successfully at the appropriate -np
> 4 level.
> There are three dynamics I would like to have that I can't see how
> to get.
>  1. Run on any number of processors. I'm sure this is simple, but I
> want to
>      know where the failure is when I attempt it.
>  2. Set the number of bytes appended to an open file in a single,
> atomic,
>      collective write operation. In my MPI-IO benchmark program I
> merely
>      got this number by having a buffer size on each processor, and
> the total
>      was the product of this times the number of processors. At the
> higher
>      level of PNetCDF I'm not sure which value I'm getting in the
> def_var
>      and put_var.
>  3. Be able to perform any number of equivalent, collective write
> operations,
>      appending to the same, open file. Simply a:
>      for ( i = 0; i < NUMRECS; i++ )
>      concept. This is basically what our scientific, simulation
> applications do in their 'dump' mode.
> Thanks,
> Marty Barnaby
