MPI_Info in pnetcdf
Wei-keng Liao wkliao at ece.northwestern.edu
Sun Jun 10 00:58:40 CDT 2007
Pnetcdf seems to assume that data type of MPI_Info is int,
which is OK if pnetcdf is built on top of MPICH2 (MPICH2
type-defines MPI_Info as int.)
But MPI_Info is defined differently in MPICH1 as
     typedef struct MPIR_Info *MPI_Info;
So, when I ran the codes below using MPICH1, I got a seg fault.
Wei-keng
% cat pnf_test.f90
program pnf_test
   implicit none
   include 'mpif.h'
# include "pnetcdf.inc"
   integer ierr, info, ncid
   call MPI_Init(ierr)
   call MPI_Info_create(info, ierr)
   call MPI_Info_set(info, 'cb_buffer_size', '1048576', ierr)
   ierr = nfmpi_create(MPI_COMM_WORLD, 'testfile.nc', &
                       NF_CLOBBER, info, ncid)
   ierr = nfmpi_enddef(ncid)
   ierr = nfmpi_close(ncid)
   call MPI_Info_free(info, ierr)
   call MPI_Finalize(ierr)
end program pnf_test
