nfmpi_create with NF_CLOBBER
Wei-keng Liao wkliao at ece.northwestern.edu
Sat Jun 9 21:06:21 CDT 2007
As defined in netCDF, when NF_CLOBBER, NC_CLOBBER is used in the cmode
argument of nfmpi_create(), the file will be overwritten if it exists.
In mpincio.c,, function ncmpiio_create, I can see that in this case, the
file is first deleted by MPI_File_delete() and later created by
MPI_File_open().
Since MPI_File_delete() is non-collective, all MPI processes will try to
delete the file simultaneously, which results in only one success and
fail for all others.
Shouldn't it be done by just having one process call delete and others
waiting at a MPI_Barrier()?
Wei-keng
