Issue with "integer" arguments in Fortran API for PNetCDF
John Michalakes john at michalakes.us
Wed Oct 25 13:24:55 CDT 2006
Fair enough... "o32" has a familiar ring to it (I vaguely remember this is
an old SGI compiler flag). But works for me. Thanks. -John
> -----Original Message-----
> From: William Gropp [mailto:gropp at mcs.anl.gov]
> Sent: Wednesday, October 25, 2006 12:10 PM
> To: john at michalakes.us
> Cc: parallel-netcdf at mcs.anl.gov
> Subject: Re: Issue with "integer" arguments in Fortran API for PNetCDF
> Well, its probably too late for that, as the Fortran version of the
> parallel interface has been out for some time and is already in use.
> The real issue is the one that I mentioned - even for 32 bit systems,
> MPI_Offset is often 64 bits, and this is a more natural (and
> necessary) size when using parallel computing, as the files can
> easily exceed 2GB.  Also, given the MPI flavor of the interface, it
> seemed natural to use MPI file offsets for these values, particularly
> as that's supported in the MPI Fortran binding.
> An alternative prefix might be nfo32mpi where the "o32" means "32-bit
> for file offset, even if MPI_Offset is 64 bits".  Redefining the
> current names (and breaking currently running code) is something I'd
> like to avoid :)
> Bill
> On Oct 25, 2006, at 12:42 PM, John Michalakes wrote:
> > Not to be too facetious, but how about "api compliant"?
> > Seriously, the NetCDF Fortran API defines these as INTEGER so if an
> > interface needs to have a name that sets it off, it should probably
> > be the
> > current Fortran interface to pNetCDF.
> > -John
> >> From: owner-parallel-netcdf at mcs.anl.gov
> >> [mailto:owner-parallel-netcdf at mcs.anl.gov]On Behalf Of William Gropp
> >> Sent: Wednesday, October 25, 2006 10:21 AM
> >> PNetCDF
> >> Actually, MPI_Offset can be 64 bits, even on 32-bit platforms, if the
> >> file system accepts 64 bit offsets (e.g., has something like
> >> lseek64).
> >> What would you suggest as a name that indicated that the offset value
> >> was a Fortran integer rather than an MPI_Offset-sized integer?
> >> Bill
> >> On Oct 25, 2006, at 11:05 AM, John Michalakes wrote:
> >>> That would be helpful. But I think putting 32 in the name would be
> >>> misleading, since this is only an issue on 64 bit compiles.  (On 32
> >>> bit
> >>> compiles, MPI_Offset is the same length as a Fortran INTEGER).
> >>> John
> >>>> Sent: Wednesday, October 25, 2006 9:51 AM
> >>>> PNetCDF
> >>>> As the Fortran interfaces are generated with a script, we could
> >>>> create an alternate version that was closer to the serial NetCDF
> >>>> interface, using a different prefix to avoid confusion (e.g., maybe
> >>>> nf32mpi_xxx).  Would that help?  What do others think of that
> >>>> approach?
> >>>> Bill
> >>>> On Oct 25, 2006, at 2:06 AM, John Michalakes wrote:
> >>>>> PS... There is a problem with the pnetcdf.inc file itself.  This
> >>>>> file
> >>>>> defines INTEGER parameters such as NF_UNLIMITED which may be
> >>>>> used as
> >>>>> arguments to NFMPI_* routines that are defined as
> >>>>> INTEGER(KIND=MPI_OFFSET_KIND). An example is the 3rd argument of:
> >>>>> FORTRAN_API int FORT_CALL nfmpi_def_dim_ ( int *v1, char *v2
> >>>>> FORT_MIXED_LEN(d2), MPI_Offset *v3, MPI_Fint *v4 FORT_END_LEN
> >>>>> (d2) )
> >>>>> Since MPI_Offset can be 64-bits if compiled with OBJECT_MODE 64 on
> >>>>> the IBM,
> >>>>> passing NF_UNLIMITED (32-bits) as the third argument is incorrect.
> >>>>> John
> >>>>>> [mailto:owner-parallel-netcdf at mcs.anl.gov]On Behalf Of John
> >>>>>> Michalakes
> >>>>>> Sent: Tuesday, October 24, 2006 3:30 PM
> >>>>>> To: parallel-netcdf at mcs.anl.gov
> >>>>>> Subject: Issue with "integer" arguments in Fortran API for
> >>>>>> PNetCDF
> >>>>>> I'm having a problem adapting parallel NetCDF as an option in
> >>>>>> the WRF
> >>>>>> (Weather Research and Forecast) model I/O API. WRF currently
> >>>>>> supports
> >>>>>> non-parallel NetCDF, and we're now trying to extend the model to
> >>>>>> use the new
> >>>>>> parallel NetCDF code. Have run into a problem with some of the
> >>>>>> arguments in
> >>>>>> the API for parallel-NetCDF:
> >>>>>> The original NetCDF Fortran API defines lengths, starts, and
> >>>>>> other arguments
> >>>>>> as INTEGER. PnetCDF recasts some (but not all) of these
> >>>>>> arguments as
> >>>>>> MPI_Offset. We compile WRF with OBJECT_MODE 64 on the IBMs where
> >>>>>> KIND=MPI_OFFSET_KIND works out to 8 bytes. Thus, the calls in WRF
> >>>>>> that pass
> >>>>>> these arguments as 32-bit INTEGERs from Fortran are causing
> >>>>>> PNetCDF to see
> >>>>>> garbage in the high four bytes of the dummy argument. For
> >>>>>> example,
> >>>>>> the
> >>>>>> length argument to NFMPI_DEF_DIM ends up being 73 + a very-large-
> >>>>>> garbage
> >>>>>> value instead of 73.
> >>>>>> I was hoping for a relatively quick drop-in of PnetCDF into WRF
> >>>>>> I/O API but
> >>>>>> this now seems unlikely. There is a large amount of NetCDF
> >>>>>> interface code in
> >>>>>> WRF that will need to be gone through.  Or I can write a wrapper
> >>>>>> lib for all
> >>>>>> these routines.
> >>>>>> Has anyone done this already? What's needed is for the wrapper
> >>>>>> routine to
> >>>>>> accept INTEGER arguments and copy them to INTEGER
> >>>>>> (KIND=MPI_OFFSET_KIND) to
> >>>>>> be used as arguments to the actual NFMPI_* routines in PNetCDF
> >>>>>> and
> >>>>>> (in the
> >>>>>> case of return values) copy them back to INTEGER again.
> >>>>>> Not arguing, but curious: since PNetCDF is supposed to be a
> >>>>>> parallel
> >>>>>> implementation of the NetCDF API, why was the API altered this
> >>>>>> way
> >>>>>> to use
> >>>>>> arguments of type MPI_Offset instead of INTEGER? At least for
> >>>>>> what
> >>>>>> I'm
> >>>>>> trying to do, it is a significant impediment.
> >>>>>> I really appreciate that parallel NetCDF is being developed. It
> >>>>>> is very much
> >>>>>> needed, especially now as we try moving to Petascale. Kudos to
> >>>>>> the
> >>>>>> developers.
> >>>>>> John
> >>>>>> John Michalakes, Software Engineer        michalak at ucar.edu
> >>>>>> NCAR, MMM Division                   voice: +1 303 497 8199
> >>>>>> 3450 Mitchell Lane                     fax: +1 303 497 8181
> >>>>>> Boulder, Colorado 80301 U.S.A.        cell: +1 720 209 2320
> >>>>>>         http://www.mmm.ucar.edu/individual/michalakes
