Issue with "integer" arguments in Fortran API for PNetCDF
Jim Edwards jedwards at ucar.edu
Wed Oct 25 11:24:21 CDT 2006
Again I solve this problem through alternatively typing the variable:
#ifdef PNETCDF
  use parallel_mod, only : nfsizekind=>mpi_offset_kind
#else
  use kinds, only : nfsizekind=>int_kind
#endif
  integer(kind=nfsizekind),parameter :: unlim_dim=nf_unlimited
On 10/25/06, John Michalakes <john at michalakes.us> wrote:
> That would be helpful. But I think putting 32 in the name would be
> misleading, since this is only an issue on 64 bit compiles.  (On 32 bit
> compiles, MPI_Offset is the same length as a Fortran INTEGER).
> John
> > -----Original Message-----
> > From: William Gropp [mailto:gropp at mcs.anl.gov]
> > Sent: Wednesday, October 25, 2006 9:51 AM
> > To: john at michalakes.us
> > Cc: parallel-netcdf at mcs.anl.gov
> > Subject: Re: Issue with "integer" arguments in Fortran API for PNetCDF
> > As the Fortran interfaces are generated with a script, we could
> > create an alternate version that was closer to the serial NetCDF
> > interface, using a different prefix to avoid confusion (e.g., maybe
> > nf32mpi_xxx).  Would that help?  What do others think of that approach?
> > Bill
> > On Oct 25, 2006, at 2:06 AM, John Michalakes wrote:
> > > PS... There is a problem with the pnetcdf.inc file itself.  This file
> > > defines INTEGER parameters such as NF_UNLIMITED which may be used as
> > > arguments to NFMPI_* routines that are defined as
> > > INTEGER(KIND=MPI_OFFSET_KIND). An example is the 3rd argument of:
> > > FORTRAN_API int FORT_CALL nfmpi_def_dim_ ( int *v1, char *v2
> > > FORT_MIXED_LEN(d2), MPI_Offset *v3, MPI_Fint *v4 FORT_END_LEN(d2) )
> > > Since MPI_Offset can be 64-bits if compiled with OBJECT_MODE 64 on
> > > the IBM,
> > > passing NF_UNLIMITED (32-bits) as the third argument is incorrect.
> > > John
> > >> From: owner-parallel-netcdf at mcs.anl.gov
> > >> [mailto:owner-parallel-netcdf at mcs.anl.gov]On Behalf Of John
> > >> Michalakes
> > >> Sent: Tuesday, October 24, 2006 3:30 PM
> > >> To: parallel-netcdf at mcs.anl.gov
> > >> Subject: Issue with "integer" arguments in Fortran API for PNetCDF
> > >> I'm having a problem adapting parallel NetCDF as an option in the WRF
> > >> (Weather Research and Forecast) model I/O API. WRF currently supports
> > >> non-parallel NetCDF, and we're now trying to extend the model to
> > >> use the new
> > >> parallel NetCDF code. Have run into a problem with some of the
> > >> arguments in
> > >> the API for parallel-NetCDF:
> > >> The original NetCDF Fortran API defines lengths, starts, and
> > >> other arguments
> > >> as INTEGER. PnetCDF recasts some (but not all) of these arguments as
> > >> MPI_Offset. We compile WRF with OBJECT_MODE 64 on the IBMs where
> > >> KIND=MPI_OFFSET_KIND works out to 8 bytes. Thus, the calls in WRF
> > >> that pass
> > >> these arguments as 32-bit INTEGERs from Fortran are causing
> > >> PNetCDF to see
> > >> garbage in the high four bytes of the dummy argument. For example,
> > >> the
> > >> length argument to NFMPI_DEF_DIM ends up being 73 + a very-large-
> > >> garbage
> > >> value instead of 73.
> > >> I was hoping for a relatively quick drop-in of PnetCDF into WRF
> > >> I/O API but
> > >> this now seems unlikely. There is a large amount of NetCDF
> > >> interface code in
> > >> WRF that will need to be gone through.  Or I can write a wrapper
> > >> lib for all
> > >> these routines.
> > >> Has anyone done this already? What's needed is for the wrapper
> > >> routine to
> > >> accept INTEGER arguments and copy them to INTEGER
> > >> (KIND=MPI_OFFSET_KIND) to
> > >> be used as arguments to the actual NFMPI_* routines in PNetCDF and
> > >> (in the
> > >> case of return values) copy them back to INTEGER again.
> > >> Not arguing, but curious: since PNetCDF is supposed to be a parallel
> > >> implementation of the NetCDF API, why was the API altered this way
> > >> to use
> > >> arguments of type MPI_Offset instead of INTEGER? At least for what
> > >> I'm
> > >> trying to do, it is a significant impediment.
> > >> I really appreciate that parallel NetCDF is being developed. It
> > >> is very much
> > >> needed, especially now as we try moving to Petascale. Kudos to the
> > >> developers.
> > >> John
> > >> John Michalakes, Software Engineer        michalak at ucar.edu
> > >> NCAR, MMM Division                   voice: +1 303 497 8199
> > >> 3450 Mitchell Lane                     fax: +1 303 497 8181
> > >> Boulder, Colorado 80301 U.S.A.        cell: +1 720 209 2320
> > >>         http://www.mmm.ucar.edu/individual/michalakes
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20061025/4b6f739e/attachment.htm>
