Issue with "integer" arguments in Fortran API for PNetCDF
William Gropp gropp at mcs.anl.gov
Wed Oct 25 10:51:19 CDT 2006
As the Fortran interfaces are generated with a script, we could
create an alternate version that was closer to the serial NetCDF
interface, using a different prefix to avoid confusion (e.g., maybe
nf32mpi_xxx).  Would that help?  What do others think of that approach?
Bill
On Oct 25, 2006, at 2:06 AM, John Michalakes wrote:
> PS... There is a problem with the pnetcdf.inc file itself.  This file
> defines INTEGER parameters such as NF_UNLIMITED which may be used as
> arguments to NFMPI_* routines that are defined as
> INTEGER(KIND=MPI_OFFSET_KIND). An example is the 3rd argument of:
> FORTRAN_API int FORT_CALL nfmpi_def_dim_ ( int *v1, char *v2
> FORT_MIXED_LEN(d2), MPI_Offset *v3, MPI_Fint *v4 FORT_END_LEN(d2) )
> Since MPI_Offset can be 64-bits if compiled with OBJECT_MODE 64 on
> the IBM,
> passing NF_UNLIMITED (32-bits) as the third argument is incorrect.
> John
>> -----Original Message-----
>> From: owner-parallel-netcdf at mcs.anl.gov
>> [mailto:owner-parallel-netcdf at mcs.anl.gov]On Behalf Of John
>> Michalakes
>> Sent: Tuesday, October 24, 2006 3:30 PM
>> To: parallel-netcdf at mcs.anl.gov
>> Subject: Issue with "integer" arguments in Fortran API for PNetCDF
>> I'm having a problem adapting parallel NetCDF as an option in the WRF
>> (Weather Research and Forecast) model I/O API. WRF currently supports
>> non-parallel NetCDF, and we're now trying to extend the model to
>> use the new
>> parallel NetCDF code. Have run into a problem with some of the
>> arguments in
>> the API for parallel-NetCDF:
>> The original NetCDF Fortran API defines lengths, starts, and
>> other arguments
>> as INTEGER. PnetCDF recasts some (but not all) of these arguments as
>> MPI_Offset. We compile WRF with OBJECT_MODE 64 on the IBMs where
>> KIND=MPI_OFFSET_KIND works out to 8 bytes. Thus, the calls in WRF
>> that pass
>> these arguments as 32-bit INTEGERs from Fortran are causing
>> PNetCDF to see
>> garbage in the high four bytes of the dummy argument. For example,
>> the
>> length argument to NFMPI_DEF_DIM ends up being 73 + a very-large-
>> garbage
>> value instead of 73.
>> I was hoping for a relatively quick drop-in of PnetCDF into WRF
>> I/O API but
>> this now seems unlikely. There is a large amount of NetCDF
>> interface code in
>> WRF that will need to be gone through.  Or I can write a wrapper
>> lib for all
>> these routines.
>> Has anyone done this already? What's needed is for the wrapper
>> routine to
>> accept INTEGER arguments and copy them to INTEGER
>> (KIND=MPI_OFFSET_KIND) to
>> be used as arguments to the actual NFMPI_* routines in PNetCDF and
>> (in the
>> case of return values) copy them back to INTEGER again.
>> Not arguing, but curious: since PNetCDF is supposed to be a parallel
>> implementation of the NetCDF API, why was the API altered this way
>> to use
>> arguments of type MPI_Offset instead of INTEGER? At least for what
>> I'm
>> trying to do, it is a significant impediment.
>> I really appreciate that parallel NetCDF is being developed. It
>> is very much
>> needed, especially now as we try moving to Petascale. Kudos to the
>> developers.
>> John
>> John Michalakes, Software Engineer        michalak at ucar.edu
>> NCAR, MMM Division                   voice: +1 303 497 8199
>> 3450 Mitchell Lane                     fax: +1 303 497 8181
>> Boulder, Colorado 80301 U.S.A.        cell: +1 720 209 2320
>>         http://www.mmm.ucar.edu/individual/michalakes
