Issue with "integer" arguments in Fortran API for PNetCDF
John Michalakes john at michalakes.us
Tue Oct 24 16:29:32 CDT 2006
I'm having a problem adapting parallel NetCDF as an option in the WRF
(Weather Research and Forecast) model I/O API. WRF currently supports
non-parallel NetCDF, and we're now trying to extend the model to use the new
parallel NetCDF code. Have run into a problem with some of the arguments in
the API for parallel-NetCDF:
The original NetCDF Fortran API defines lengths, starts, and other arguments
as INTEGER. PnetCDF recasts some (but not all) of these arguments as
MPI_Offset. We compile WRF with OBJECT_MODE 64 on the IBMs where
KIND=MPI_OFFSET_KIND works out to 8 bytes. Thus, the calls in WRF that pass
these arguments as 32-bit INTEGERs from Fortran are causing PNetCDF to see
garbage in the high four bytes of the dummy argument. For example, the
length argument to NFMPI_DEF_DIM ends up being 73 + a very-large-garbage
value instead of 73.
I was hoping for a relatively quick drop-in of PnetCDF into WRF I/O API but
this now seems unlikely. There is a large amount of NetCDF interface code in
WRF that will need to be gone through.  Or I can write a wrapper lib for all
these routines.
Has anyone done this already? What's needed is for the wrapper routine to
accept INTEGER arguments and copy them to INTEGER(KIND=MPI_OFFSET_KIND) to
be used as arguments to the actual NFMPI_* routines in PNetCDF and (in the
case of return values) copy them back to INTEGER again.
Not arguing, but curious: since PNetCDF is supposed to be a parallel
implementation of the NetCDF API, why was the API altered this way to use
arguments of type MPI_Offset instead of INTEGER? At least for what I'm
trying to do, it is a significant impediment.
I really appreciate that parallel NetCDF is being developed. It is very much
needed, especially now as we try moving to Petascale. Kudos to the
developers.
John
John Michalakes, Software Engineer        michalak at ucar.edu
NCAR, MMM Division                   voice: +1 303 497 8199
3450 Mitchell Lane                     fax: +1 303 497 8181
Boulder, Colorado 80301 U.S.A.        cell: +1 720 209 2320
        http://www.mmm.ucar.edu/individual/michalakes
