Problems with Linux Build of parallel netcdf
Richard Hedges richard-hedges at llnl.gov
Wed Oct 5 12:52:51 CDT 2005
I am building the official release of 1.0 on an ia32 Linux CLuster
using Intel compilers (version 8.0).
I am seeing a bunch of unexpected failures in the verification suite,
in particular  of the tests
n[c,f]mpi_put_var*_float , getting diagnostics such as "Numeric
conversion not representable" or
"Var  value read not that expected"
I am using the following settings:
    setenv MPICC  "mpiicc -lmpio"
    setenv MPIF77 "mpiifort -lmpio"
    setenv F77    ifort
    setenv FC     ifort
    setenv CC     icc
The same settings work fine on an ia64 Linux System.
Is there a known problem with the Intel compilers, or is something
more needed re. the settings?
- Richard
Richard Hedges
Scalable I/O Project
Development Environment Group - Livermore Computing
Lawrence Livermore National Laboratory
7000 East Avenue, MS L-557
Livermore, CA	94551
v:	(925) 423-2699
f:	(925) 423-6961
E:	richard-hedges at llnl.gov
