NF_GLOBAL and nfmpi_put_var_real
Jianwei Li jianwei at ece.northwestern.edu
Mon May 9 12:04:08 CDT 2005
Hi Yu-Heng,
Thanks to Rene sharing the experience with pnetcdf
fortran interface.
I have one more comment regarding your point 2:
Did you happen to call the independent data access
function in the collective data mode?
Could you check your "ierr" and print out the
error message using our nfmpi_strerror() interface?
It might be possible that all the "nfmpi_" functions
you added didn't successfully execute at all if they
are called in an unexpected mode (as documented in
our API docs).
Jianwei
On Mon, 9 May 2005, Rene Redler wrote:
> P.S.:
> I forgot to mention that probably all dimensions need to be
> declared as I described in my previous mail. For my if was
> helpful to take a look into pnetcdf/src/libf/mpifnetcdf.h
> to learn what is expected to the respective calls, although
> this is probably not the way the developers like us to go ;)
> In your example below
> ierr=nfmpi_def_var(ncid,"P0",NF_REAL,0_8,0_8,t_id)
> will probably help to force the 0 arguments passed as
> integer*8 to the lib functions.
> Yu-Heng Tseng schrieb:
>> Hi,
>> I got some problems in the testing.
>> 1. It seems  NF_GLOBAL causes some errors in  nfmpi_put_att_text().
>> Same thing  happens to NF_UNLIMITED
>> Is that right?
>> 2. nfmpi_put_var_real() seems not giving me right answer.
>> I added a couple of lines within the test program (/fandc/pnf_test.F).
>> real*4 pt
>> pt=5.0
>> ierr=nfmpi_def_var(ncid,"P0",NF_REAL,0,0,t_id)
>> ierr=nfmpi_put_var_real(ncid,t_id,pt)
>> It goes wrong in the output. Same for nfmpi_put_var_double() etc
>> Any idea how to fix this?
>> Thanks!
>> Cheers
>> Yu-heng
