Partial output problem
Yu-Heng Tseng YHTseng at lbl.gov
Fri Jul 22 00:50:58 CDT 2005
I am testing nfmpi_vara_put_all() in Fortran
which can output subarray using
mpi_type_create_subarray() to specify partial
array. The test example works fine if I output
the subarrays from all processors.
However, I got some problems when outputing only
partial arrays from some of the processors (not all of them).
the mpi_type_create_subarray() gives me error
if I specify count=0 (not output from that particular processer).
ERROR: 0032-309 Invalid array element  (0) in
MPI_Type_create_subarray, task 1
For example, process 0 has array [1 2;3 4;5 6]
process 1 has array [7 8; 9 10; 11 12].
If I only want to output [1 2] from process 0.
I specify count=0 in process 1. It seems this statment
is not allowed in mpi_type_create_subarray().
Any other way to avoid this problem using parallel netCDF?
Thanks!
Yu-heng
Type: text/x-vcard
Desc: Card for Yu-Heng Tseng <YHTseng at lbl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20050721/0f98db04/attachment.vcf>
