more fortran tests with pnetcdf
Robert Latham robl at mcs.anl.gov
Mon Apr 18 11:43:25 CDT 2005
On Mon, Apr 18, 2005 at 05:39:23PM +0200, Rene Redler wrote:
> hi,
>    I made some more tests with the pnetcdf lib on several
> systems, each one showing a different and probably wrong
> behavior.
thanks for exercising our fortran interface so thouroughly.
> nf_test -c  and nf_test -r run on all systems. There is
> possibly something wrong when testing nfmpi_open. Here
> 3 failures are produced during the -r test which should
> probably only be one. I misinterpreted the final output,
> and I need to have a closer look into it.
> My first question is whether someone has managed to run
> the full nf_test on a 32 Bit System successfully?
I get the expected 3 failures under linux with g77.  That could mean
everything is fine, or it could mean there's a bug in the test,
though.
> My test.nc contains for var_name ir:
>  ir = -2147483648, 2147483647 ;
That's what i get.
> Any suggestions about what might go wrong here are more than
> welcome since I am running out of ideas.
I'm not sure right now.  I'll try things out on one of the 64 bit machines
around here and let you know.
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Labs, IL USA                B29D F333 664A 4280 315B
