turning off file locking
Rajeev Thakur thakur at mcs.anl.gov
Wed May 19 17:21:02 CDT 2004
The problem with NFS is that by default it does not guarantee that
concurrent writes from two or more processes to different locations
(non-overlapping bytes) in a single file will appear in the file. NFS
clients are allowed to cache data locally at the granularity of a page or
more. To support parallel I/O as defined by MPI-IO, we need to turn off
client-side caching in NFS. There is no reliable way to do that either, but
locking the byte-range being read or written with fcntl file locks for every
read or write seems to work.
The real recommendation is to not use NFS at all for parallel I/O.
The locking refered to for MPI_MODE_UNIQUE_OPEN under "Advice to
Implementers" is of a different type -- when the MPI-IO implementation
itself does some caching of its own.
Rajeev
> -----Original Message-----
> From: owner-parallel-netcdf at mcs.anl.gov
> [mailto:owner-parallel-netcdf at mcs.anl.gov] On Behalf Of
> Drake, Richard R
> Sent: Wednesday, May 19, 2004 5:07 PM
> To: 'parallel-netcdf at mcs.anl.gov'
> Subject: RE: turning off file locking
> I agree that NFS file locking is insufficient, therefore, can
> it be turned off?  At least when I will only be writing a new file.
> Looking at the MPI-2 spec, the MPI_MODE_UNIQUE_OPEN mode to
> MPI_File_open() says "...allows an implementation to optimize
> access by eliminating the overhead of file locking."
> Does pnetcdf open the file more than once using
> MPI_File_open() and expect MPI-I/O to handle the
> syncronization correctly, or does pnetcdf open the file
> uniquely (at least amongh the MPI processes for that job).
> If so, then why can't file locking be turned off?
> On the other hand, if MPI-I/O will not function correctly
> without file locking, then there is a bug or lacking feature
> in the implementation (at least according to MPI-2).
> -rich
> From: Richard Hedges [mailto:richard-hedges at llnl.gov]
> Sent: Wednesday, May 19, 2004 3:23 PM
> To: Foucar, James G
> Cc: 'parallel-netcdf at mcs.anl.gov'
> Subject: Re: turning off file locking
> >Hello, I have been having off and on problems with file
> locking on NFS
> >when using pnetcdf. The error i get is:
> >File locking failed in ADIOI_Set_lock. If the file system is
> NFS, you
> >need to use NFS version 3 and mount the directory with the 'noac'
> >option (no attribute caching).
> >My question is: is there anyway turn off file locking for
> the pnetcdf
> >file?
> >Thanks,
> >James
> Well, I think that the complaint is that the file locking in NFS is
> not adequate for the parallel operations that you are attempting.
> Things you can do:
> 1) use a real parallel filesystem (GPFS, CPFS, PVFS, Lustre: not NFS)
> 2) if an SMP node is big enough, use a local filesystem on an
> SMP node.
> 3) mount NFS without attribute caching (as recommended in the
> diagnostic message)
> - Richard
> Richard Hedges
> Scalable I/O Project
> Development Environment Group - Livermore Computing
> Lawrence Livermore National Laboratory
> 7000 East Avenue, MS L-550
> Livermore, CA	94551
> v:	(925) 423-2699
> f:	(925) 423-1173
> E:	richard-hedges at llnl.gov
